04-17-2014, 02:32 PM - 1 Like   #1
GUB's Avatar
Pentax 110 50mm on the Q
I think we will see a lot more people using this lens on the Q as they master the art of applying a diaphragm to stop it down. The New Zealand native Robin is about the size of a sparrow and lives in deep gloomy forest. The good thing is it is inquisitive and can't resist checking you out. Spot the shutter speed (1/10sec!!) . Don't let anyone tell you SR on the Q doesn't work!! The system rocks.
This was taken with the lens stopped down to about f4
PENTAX Q  Photo
04-17-2014, 03:27 PM   #2
Lowell Goudge's Avatar
Nice shot and thanks for posting.
I have asked the moderators to make the lenses on the Q index a sticky to keep it at the top of the page
05-09-2014, 10:50 AM   #3
littledrawe's Avatar
QuoteOriginally posted by GUB Quote
How did you do it? I bought lens baby aperture disks to put inside the Q to 110 adapter for an 110 18mm lens I found on the cheap. Unfortunately the results from that lens have been underwhelming.
05-09-2014, 10:56 AM   #4
QuoteOriginally posted by littledrawe Quote
18/2.8 or the 18 pan focus? I imagine the pan focus is probably not the greatest lens, but it is kinda rare -- you could make some money selling it if you got it cheap. I've got the 50 and the 70 and they are both quite sharp on the Q...
05-09-2014, 11:20 AM   #5
18/2.8
This is the one. I've been trying to think if there is something I'm doing wrong but maybe it just isn't a great lens but I can't ask for too much from something that fell within the bound of the hamburger rule.
05-09-2014, 12:56 PM   #6
Hmmm...I've heard good things about the 18/2.8 just like the rest of them, and searching for samples they look fine. They all seem quite well-made. I wasn't much interested in the 18 only because it is pretty close to what is already covered by the native Q lenses. What disc have you put into it? (I think you have to use the f/8 disc or smaller to have any effect -- I forget.)
05-09-2014, 02:13 PM   #7
GUB
GUB's Avatar
For f4 you need a 6mm diameter aperture. I am using a ringbinder reinforcing ring with both sides felttip black except for about 1mm of the sticky side. This then sticks onto the back lens surround.
https://www.pentaxforums.com/forums/136-pentax-q/256849-comparing-adapted-lenses-q-4.html
The rear lens is about 9mm diameter. So if that is f2.8 then f4 will be just over 6mm , f5.6 will be the square root of 20 => 4.5mm and f8 the square root of 10 => 3.2mm.
(So long as it is close to the back of the len)
That is the theory anyway
A lot of people are using lensbaby rings but they are not true to label . From memory the f11 one did about f5.6 on the Q. If you use these make sure you get them as close to the lens as possible.
---------- Post added 05-10-14 at 09:23 AM ----------
Check that the focus thread grease has not migrated to the internal glass. They have a relatively simple construction so this can happen easily (and is easily cleaned).
aperture, camera, diameter, disks, f4, f5.6, lens, pentax 110 50mm, pentax lens, results, root, sample photo, square
110 Adapter for Pentax Q Clinton Pentax Q 5 07-20-2014 12:30 PM
For Sale - Sold: Pentax Q system: kit w/01, 02, 03, PK adapter, auto 110 24mm and 70mm lenses Nick Siebers Sold Items 3 10-24-2013 08:54 AM
How are the Auto 110 lenses on the Q? ChopperCharles Pentax Q 37 05-20-2013 09:47 PM
new Pentax's with Q/110 mount?? i_trax Pentax Q 7 09-08-2012 04:53 PM
Quick Review: Pixco Pentax 110 to Q Mount adaptor cjfeola Pentax Q 4 06-22-2012 05:54 AM
All times are GMT -7. The time now is 06:08 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
