I found this lens in a bin at a thrift shop and picked up up for a few dollars because it was pretty clean and had a screw mount. I've searched high, low, wide, near, and far but have begun to think that this is the only 90 to 210 ever produced. Lens facia and zoom ring both say 90, It has only four stops - 4, 8, 11, and 16, no half stops in there. The macro slider rotates the macro ring about 90 degrees, focus ring is multi turn. One of my adapters keeps the aperture pin down, there is no manual switch. I've had it a half dozen years and today took it outside to try it out I it has a little haze inside, not bad yet but I think it causes a bit of washed out appearance. I may have shoot some more to make sure that none of the softness is attributable to focus and to evaluate the bokeh.
Following are some photos of the lens and a few photos. The palm tree was hand held at 210mm, followed by a crop at pixel level, the flowers were taken in macro position and the last photo was processed for noise, contrast, saturation etc.
Not a bad $10 lens. If anyone knows or can deduce anything about the lens, I would be interested in hearing it, I suspect that this was sold as an 80-210 by someone, but I haven't been able to match it based on appearance of the ones I compared.
