05-11-2021, 05:20 PM   #16
johnha's Avatar
It's worth pointing out that my QDOS version also had a Ricoh pin as well as the KA mount.
05-11-2021, 06:31 PM   #17
Seeker of Knowledge
aslyfox's Avatar
QuoteOriginally posted by johnha Quote
Third Party Variants of the K-mount
Pentax made the original "K" mount available for other camera manufacturers to adopt. The goal was to create a universal standard bayonet mount much like the M42 screw mount had been. Ricoh, Chinon, and others produced cameras and lenses with the "K" mount. Unfortunately, with the introduction of the "KA" mount, Pentax reversed the decision with the result that the other manufacturers either abandoned the "K" mount or developed their own, somewhat incompatible, enhancements. Several third party lens manufacturers produce or has produced lenses with a K-mount. There are no issues with current third party lenses in K-mount, but for older lenses there are two traps to watch out for:
The infamous "Ricoh pin". Where Pentax created the "KA" mount in order to support Program and Tv exposure automation, Ricoh had to create their own variant, which has a protruding pin placed in a somewhat unfortunate location, namely in the exact spot where Pentax years later placed the autofocus drive shaft. Such a Ricoh lens will get stuck when mounted on a Pentax autofocus body - the Ricoh pin will get lodged in the drive shaft and prevent the lens from being removed without deployment of finesse, patience and tools.. . .
Read more at: https://www.pentaxforums.com/articles/photo-articles/evolution-of-pentax-k-m...#ixzz6ubtnMBTj
05-12-2021, 01:16 AM   #18
D1N0's Avatar
Which reminds me of the super slow aperture blades of my Komine version.... That also has a Ricoh pin, but nothing to worry about. Only some crappy cheap third party glass has a Ricoh pin that will catch. It needs to be rounded and receded. If it is squared of don't use the lens or try to remove the pin (without loosing the a contact or the little aperture ball bearing .)
05-12-2021, 03:07 AM   #19
Andrea K's Avatar
QuoteOriginally posted by D1N0 Quote
Komine version with super slow aperture blades here... is there a solution? With film cameras isn't a problem but with the K-1 is unusable
05-12-2021, 03:21 AM   #20
bygp's Avatar
I just tested this morning my second Series 1, it's the 2nd gen made by Tokina f3.5, and indeed, its IQ is awesome, even at 70 or 210mm, just as a good prime lens !
10/10 Bokeh, 10/10 sharpness, no CA at all, light reflects make a soft 6 branch star.
It has a 6 blades diaph. but the blades are well curved so the bokeh is huge !
Maybe mine needs a little infinity focus calibration, or I shall test again higher than f8...
I'll keep both, one for easier handling (the cosina) and the Tokina for super IQ photos
05-12-2021, 04:19 AM   #21
@D1N0, @ Andrea K
see my fix of the komine 70-210mm blades:
Vivitar (komine) 70-210mm, PK-A mount, sticky iris repair. - PentaxForums.com
05-12-2021, 12:54 PM   #22
Lowell Goudge's Avatar
added to the index as version 4 (Cosina)
05-12-2021, 02:24 PM - 1 Like   #23
Otis Memorial Pentaxian
...or some Ricoh Rikenon-P and not-so-cheap third-party lenses from before Pentax released its KAF bodies. The "safe" versions of the Ricoh pin are found on lenses that date to sometime after the debut of Pentax AF cameras in 1987, when the incompatibility became obvious. (The pin itself dates to 1984.)
Added: The "safe" version is a spring-loaded ball-type contact. Any that look like a pin (rounded or not) should be assumed to be unsafe.
05-13-2021, 03:27 AM   #24
Andrea K's Avatar
QuoteOriginally posted by marcusBMG Quote
@D1N0, @ Andrea K
Without the Brexit and his customs fees I would have sent it to you ...
05-13-2021, 04:34 AM   #25
D1N0's Avatar
@D1N0, @ Andrea K
Thanks. I already had it stored as a project, but I always fear I will just totally mess it up. It seems to have gotten even worse now it is not just slow but practically stuck. Only manually handling the lever will make it close.
05-13-2021, 06:09 AM   #26
I'll coach you over zoom... Just have to take a deep breath and get stuck in. it was the same with the vivitar komine 400mm I had in my box for ages. When i finally did it it was easy.
Look around for a camera/lens techie, I'm sure there must be one who can look at the online ino and go yeah no prob, Andrea.
70-210mm f2.8, 8 blades, blades ka, camera, f2.8 8 blades, lens, pentax lens, sample photo, series 1 70-210mm, vivitar, vivitar series, vivitar series 1 70-210mm
For Sale - Sold: KIRON [Lester A Dine/Vivitar Series 1] 105mm F2.8 MACRO KA mount UPS Shipping steamloco76 Sold Items 4 01-08-2021 08:37 AM
RMC Tokina 70-210mm F3.5 is the same as Tokina Vivitar Series I 70-210mm ? minahasa Pentax SLR Lens Discussion 11 09-17-2011 09:59 AM
Vivitar Series 1 70-210mm f/2.8-4 Zoom Lens Pentax KA sdreyer Pentax SLR Lens Discussion 3 02-06-2010 11:56 PM
For Sale - Sold: Vivitar Series 1 (Version 3) 70-210mm 2.8-4 P/KA Lens Curbster54 Sold Items 3 12-04-2009 11:27 AM
For Sale - Sold: Vivitar Series 1 P/KA 70-210mm f/2.8-4 Macro Focusing Zoom Lens wallyb Sold Items 2 08-10-2009 07:53 PM
All times are GMT -7. The time now is 04:22 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
