05-11-2021, 10:41 AM - 1 Like   #1
bygp's Avatar
Vivitar Series 1 70-210mm f2.8 - 8 blades KA mount
Did I bought the best model of this serie ? Its IQ is awesome and it is super fast ! + I got it in realy mint condition with its leather box
PENTAX K-5  Photo
05-11-2021, 10:44 AM   #2
Prohibitiory's Avatar
This is great
05-11-2021, 10:49 AM   #3
bygp's Avatar
Was unable to find it in the lenses reviews... do you want one ?
05-11-2021, 11:02 AM   #4
Seeker of Knowledge
aslyfox's Avatar
QuoteOriginally posted by bygp Quote
the serial number will tell you
There are six versions of the manual focus Vivitar Series 1 (VS1) 70-210 zoom lenses, all of which can be distinguished apart from each other visually (and their manufacturers can be identified by using their serial numbers). Interestingly, Vivitar was never actually a lens manufacturer per se -- Vivitar contracted with various lens makers to produce lenses to its own specifications, which it then marketed under the Vivitar brand (although the contractors would sometimes end up releasing similar lens designs under their own and/or other brands), and this always-a-lens-specifier-and-never-a-lens-maker characteristic is certainly true for all the VS1 70-210 zooms. . . .
Vivitar Series 1 70-210mm Line Lens Reviews - Vivitar Lenses - Pentax Lens Review Database
05-11-2021, 11:04 AM   #5
bygp's Avatar
it has a ruber zoom/focusing and has a 58mm front diameter ring for filters/hoods
---------- Post added 05-11-21 at 11:06 AM ----------
QuoteOriginally posted by aslyfox Quote
Serial N is : 09941685
PENTAX X-5  Photo
05-11-2021, 11:22 AM   #6
Lowell Goudge's Avatar
i believe it is already in the index
Vivitar Series 1 70-210mm f/2.8-4 (third edition Komine)) - PentaxForums.com
05-11-2021, 11:23 AM   #7
bygp's Avatar
the prefix says it is a COSINA lens
05-11-2021, 11:47 AM   #8
Thats the 4th gen cosina version. Tends to be overlooked in favour of the 3rd gen komine (28xxxx serials) version. But probably still a good lens. fyi
https://www.robertstech.com/vivitar.htm
05-11-2021, 12:02 PM   #9
UncleVanya's Avatar
Very nice shot!
05-11-2021, 12:05 PM   #10
bygp's Avatar
QuoteOriginally posted by marcusBMG Quote
Vivitar 70-210 Series 1 Macro Zoom Lenses - Mark Roberts Photography
I've seen there is 4th and 5th gen, mine is 58mm front lens, how can I know if it is the QDOS or not ?
05-11-2021, 12:20 PM   #11
Otis Memorial Pentaxian
This ^ ^ ^
05-11-2021, 12:24 PM   #12
Seeker of Knowledge
aslyfox's Avatar
not that version
perhaps this one
Description:
The fourth version of the Vivitar Series 1 70-210 MF zoom series was manufactured by Cosina (SN 09nnnnnn), from about 1987 to perhaps 1995. The most obvious difference between this version (as well as the two that followed) to the previous three versions was in the action of the sliding zoom and focus collar -- to zoom closer (toward 210mm) on these Cosina versions, the one-touch zoom ring had to be pushed outward, unlike on the first three versions, where the zoom ring had to be pulled closer to zoom in.
Read more at: Vivitar Series 1 70-210mm f/2.8-4 Version 4 (Cosina) Lens Reviews - Vivitar Lenses - Pentax Lens Review Database
or
Description:
This is not only the Cosina-made 5th version of the well-respected Series 1 70-210mm zooms, but also is uniquely capable of capturing red/cyan anaglyphs in a single shot.
The lens has 14 elements in 11 groups, does macro to 1:2.5, is lighter than the first 3 versions, and takes a smallish 58mm filter. Macro does not have a separate switch, but is entered via simply focusing past the normal near stop when the lens is set at its maximum focal length.
The Q-DOS anaglyph support consists of a segmented half red, half cyan filter that is internally inserted/removed near the aperture blades by a QDOS/normal switch (right in photo). Q-DOS is only recommended to be used at focal lengths between 135-210mm (marked left in photo), with the lens close to wide open, and the subject fairly close. The captured images need no special processing, but are directly viewable stereo anaglyphs using red/cyan glasses.
Read more at: https://www.pentaxforums.com/userreviews/vivitar-series-1-70-210mm-f-2-8-4-0...#ixzz6uaP0XFR4
look at large size photo in the review
05-11-2021, 01:04 PM   #13
bygp's Avatar
I also have this model : Vivitar Series 1 70-210mm f/3.5 (Version 2) - made by Tokina Lens Reviews - Vivitar Lenses - Pentax Lens Review Database
which is better rated in terms of IQ
Mine is clean optically and mechanically, VMC is written in blue
Shall I run a test on it and keep it ?
its only issue it that front barrel had a shock and I can fix no filter on it, but does it need any ?
Just tested it in low light conditions at f3.5 :
PENTAX K-5  Photo
05-11-2021, 02:54 PM - 1 Like   #14
johnha's Avatar
The QDOS version has a switch near the aperture ring which moves a magenta filter in one half if the aperture and a blue filter in the other half.
05-11-2021, 04:34 PM   #15
bygp's Avatar
QuoteOriginally posted by johnha Quote
Mine is not a QDOS and BTW I absolutely don't need that, thank you anyway for this info.
70-210mm f2.8, 8 blades, blades ka, camera, f2.8 8 blades, lens, pentax lens, sample photo, series 1 70-210mm, vivitar, vivitar series, vivitar series 1 70-210mm
For Sale - Sold: KIRON [Lester A Dine/Vivitar Series 1] 105mm F2.8 MACRO KA mount UPS Shipping steamloco76 Sold Items 4 01-08-2021 08:37 AM
RMC Tokina 70-210mm F3.5 is the same as Tokina Vivitar Series I 70-210mm ? minahasa Pentax SLR Lens Discussion 11 09-17-2011 09:59 AM
Vivitar Series 1 70-210mm f/2.8-4 Zoom Lens Pentax KA sdreyer Pentax SLR Lens Discussion 3 02-06-2010 11:56 PM
For Sale - Sold: Vivitar Series 1 (Version 3) 70-210mm 2.8-4 P/KA Lens Curbster54 Sold Items 3 12-04-2009 11:27 AM
For Sale - Sold: Vivitar Series 1 P/KA 70-210mm f/2.8-4 Macro Focusing Zoom Lens wallyb Sold Items 2 08-10-2009 07:53 PM
All times are GMT -7. The time now is 03:57 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
