08-09-2011, 10:49 PM   #1
davizarc
Guest
[langtitle=es]visor k20d[/langtitle]
S:O:S
Buenas noches a todos....la funcion de vista previa no está funcionando en la pantalla lcd,no obtengo ninguna imagena al hacer girar el interruptur principal.....adicionalmente la informacion de todos los datos en la parte baja del visor no aparecen y solo funciona el punto rojo de enfoque.
En donde puede estar el daño o si es posible bloquear dicha informacion en la parte baja del visor.??
Pude haber bloqueado o dañado dicha informacion al limpiar los espejos??
Gracias de antemano por la colaboracion recibida
08-10-2011, 01:15 AM   #2
Ash
Community Manager
Ash's Avatar
Do we have the translation tool enabled for this (and other visitor) posts?
Translation from Spanish:
Good night all .... the preview function is not working on the LCD screen, I get no images to rotate the main interruptur further information ..... all the data at the bottom of the Viewfinder appear and only works the red dot.
Where can be the damage or if such information can be locked at the bottom of the viewfinder.?
I could have blocked or damaged such information to clean mirrors?
Thanks in advance for the cooperation received
_____________________________________________________________
davizarc,
Sounds like you're describing two separate problems, one with the rear preview screen and one with the viewfinder. It is going to be hard to troubleshoot without any further information, such as whether this is a new problem or if it has always been there, and whether you have a very low setting for the screen brightness in the menus.
Hopefully it's a simple problem with a simple solution, but let us know more about it.
08-10-2011, 03:39 PM   #3
Sometimes it fails to auto-detect the language if there are lots of spelling errors. To translate a post, simple wrap it in [ lang = xx] [ /lang ] where xx is the language code (in this case, es).
baja, camera, del, el, informacion, los, pentax help, visor
visor k20d davizarc Visitors' Center 1 08-08-2011 07:50 AM
Af MAL EN VISOR, BIEN EN LA FOTO Augusto Troubleshooting and Beginner Help 3 04-20-2011 09:52 AM
Acquisto pentax negli Stati Uniti e garanzia Internazionale Mitch Photographic Technique 3 12-07-2010 03:16 AM
K20D and K100DS Jakes Pentax DSLR Discussion 2 12-02-2010 12:39 PM
All times are GMT -7. The time now is 10:45 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
