09-20-2011, 11:36 AM   #1
JimHare
Guest
Confirm - K mount on Takumar 70-200 F ?
I just scored the above lens on eBay for under $30 - I hear semi-good things about it. I assume it has the Pentax K mount? I'm going to be fitting it on a Canon 50D so I know I need an adapter. Just wanted to be sure. I have two older Tak's, a 135mm and a 200mm but they both have the older screw mounts. The lens outer barrel at the front just says "Takumar A Zoom 1:4 70-200mm"
If anyone can confirm that mount on this lens, I'd really appreciate it. Thanks much!
09-20-2011, 12:34 PM   #2
eddie1960's Avatar
it is this lens i believe
Takumar-A 70-200mm F4 Macro Reviews - Non-& Other Zoom Lenses - Pentax Lens Reviews & Lens Database
So yep K mount
not the ideal unit for mounting on Canon, the m42 stuff is better for that.
09-20-2011, 12:54 PM   #3
causey's Avatar
Although named "Takumar", this lens has the K mount. I think you will need to modify the mount to use it on a Canon camera. There isn't any Pentax K to Canon adapter as far as I know. *Real* Takumar lenses work on any dslr with an adapter, just like any M42 lens out there.
09-20-2011, 10:29 PM   #4
RioRico's Avatar
Lenses labeled Takumar or Super-Takumar or Macro-Takumar or Tele-Takumar or SMC Takumar have an M42 screwmount. Lenses labeled Takumar-A or Takumar-F or Takumar Bayonet have the PK bayonet mount. These latter, nicknamed Tak-A and Tak-F and Tak-B, are generally considered to be a bit lower quality than 'real' Takumars; so if they are described accurately by sellers, they tend to fetch lower prices.
Some sellers deliberately omit the -A or -F or Bayonet descriptor, and post obscured photos to hide that. This is a similar trick to referring to a K-mount 50mm F1:2 as f/1.2 -- eBay's search tool can't distinguish between ':' and '.' -- and unwary buyers may find themselves overpaying for a rather less valuable lens than they'd thought.
09-21-2011, 05:37 AM   #5
JimHare
Guest
Thanks!
Thank you all for the guidance. I have a PK to EOS adapter in hand, but it does not 'lock' on the Tak-A very well. Not sure if I want to spend more $$ to get one, or just recycle the lens somewhere else. My investment is minimal, but as you've noted, it's not Pentax's best effort.
camera, lens, pentax help
M42 adapter for pentax mount with focus confirm? zoe Pentax SLR Lens Discussion 6 03-24-2013 09:35 AM
DA* 16-50: AF confirm issues at infinity nicolas1970i Pentax SLR Lens Discussion 2 12-27-2010 02:56 AM
Does the K-X have manual focus confirm with ...... dude163 Pentax SLR Lens Discussion 13 05-22-2010 02:46 PM
Confirm mount. Simon23 Pentax SLR Lens Discussion 4 06-09-2009 03:15 PM
For Sale - Sold: M 50/f1.4, Takumar 135/f2.5, Super Tak 28/f3.5, Tokina 80-200/f2.8, M 80-200/f loudbay Sold Items 11 03-07-2008 04:53 PM
All times are GMT -7. The time now is 04:50 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
