Originally posted by mpmetro full format... not quick format.
There is no advantage to this for an otherwise healthy card. All a "full" format does differently is force a scan for bad sectors, which is mainly geared towards normal hard drives.
Originally posted by wcchamp18 Format it via the camera options for best results prior to use. It is not recommended to format it on the computer and then use it.
There's no advantage to this either, assuming you're using Windows to format it. If one's only options are linux or mac, then perhaps the camera is a better choice - although as long as the correct filesystem and options are set, it shouldn't matter at all. That said, there is absolutely nothing wrong with using the camera's format function to do it.
