09-26-2011, 11:26 AM   #1
Unregistered
Guest
shutter speed
Hello I'm a newbe to the forum. I have the K20D and trying to shoot highschool football games.
I'm having issues with blurred photos. My ISO is set to 3200 and I'll set the camera to aperature priority and will get nothing better than 1/90 for the shutter. The same goes if I shoot manually. Can anyone tell me what I'm doing wrong or is it the capability of the camera. Other people are shooting at much faster speeds. Please help.
09-26-2011, 12:00 PM   #2
Put your camera in shutter priority and select a higher value
If you can't select anything higher, you should get a lens with a larger aperture, such as the tamron 70-200mm, which is great for sports.
Tamron 70-200mm f/2.8 Di LD (IF) Macro AF Lens AF001P-700 B&H
09-26-2011, 12:03 PM   #3
JinDesu's Avatar
You are setting it in aperture priority, but what aperture value are you using?
09-26-2011, 01:25 PM   #4
RioRico's Avatar
Set the mode dial to TAv.
Set the aperture wide-open.
Set the shutter to 1/500 second or faster.
Set the ISO range to 100-3200 (or 200-3200 if using D-range).
Set Metering and AF to Center-Weighted.
Set Drive mode to Continuous-Lo.
Do NOT set format to RAW+.
Set SR on and AF to AF-S.
Get out and shoot.
What happens with this setup: The shutter is fast enough to stop most motion. The aperture is a wide as it gets, for shallow DOF. The ISO will float to whatever level is appropriate. Keep your subject centered in the frame for most accurate AF and metering. With Continuous Drive, holding the shutter will grab 2.3 frames per second, not slowed down by RAW+ processing. That's the Spray-and-Pray strategy. It works. Good luck!
camera, pentax help, shutter
Shutter speed ronald Video and Pentax HDSLRs 15 04-03-2011 07:24 AM
Pentax KX Shutter starting to stuck at slow shutter speed. Spirit722 Pentax Film SLR Discussion 7 03-03-2011 09:49 PM
Shutter speed on K-x CrabShadow Troubleshooting and Beginner Help 7 08-14-2010 06:46 AM
Kx (or K7) Controlling shutter speed? Coby Video and Pentax HDSLRs 28 01-06-2010 05:20 AM
what shutter speed did i use? pete_pf Pentax SLR Lens Discussion 9 10-20-2009 01:45 PM
All times are GMT -7. The time now is 07:56 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
