10-20-2011, 08:38 AM   #1
Kapetz
Guest
not work lcd K2000
Добрый вечер .
Pentax k2000 не работает LCD display в чём может быть проблема ?
Разобрал , следов влаги и механических повреждений нет.
Никто не встречался с данной проблемой ?
Good evening.
Pentax k2000 is not working LCD display what could be the problem?
Make out traces of moisture and mechanical damage there.
No one met with this problem?
10-20-2011, 11:37 AM   #2
If you're looking at component failure, why not look in to upgrading to a K-r?
10-20-2011, 04:28 PM   #3
Kapetz
Guest
вы имеете ввиду обновление п/о до K-r ?
Как это можно сделать ? Просто прошить прошивкой от K-r ?
Пробовал обновить родную ( с карты памяти) - не получается... Кабель USB обезателен ?
you mean the update s /w to K-r?
How can I do? Just flash the firmware of Kr?
I tried to upgrade their home (with card) - does not work ... The USB cable is required?
10-22-2011, 12:53 PM   #4
Marc Sabatella's Avatar
Is this a camera that previously worked then stopped? You aren't by chance expecting this camera to have Live View, are you? It does not.
10-24-2011, 06:38 AM   #5
sterretje's Avatar
QuoteOriginally posted by Kapetz Quote
No, you can not upgrade the firmwire of the K2000 to firmware for the K-r don't even try it. What Adam means it might be time to upgrade your camera to a newer model; it might not be worth the cost of the repair.
camera, display, k2000, lcd, pentax, pentax help
Why wont my lens work for my k2000 pgfilms Troubleshooting and Beginner Help 2 11-18-2010 07:46 PM
Kx/K2000 Flash AF assist doesn't work in all modes? opiedog Pentax DSLR Discussion 5 09-23-2009 06:44 PM
k2000... does M lens will work... how? metungnasi Pentax DSLR Discussion 4 03-29-2009 07:47 PM
On-camera LCD vs Computer LCD Andi Lo Pentax DSLR Discussion 6 02-07-2009 01:59 AM
K10 LCD vs K20 LCD wildboar Pentax DSLR Discussion 2 10-07-2008 01:56 PM
All times are GMT -7. The time now is 06:50 AM. | See also: NikonForums.com, part of our network of photo forums!
