10-30-2011, 02:30 PM   #1
FreelancePolice
Guest
K-X manual mode does not work with Pentax-M 1:3.5 24-35mm
Hi all,
I have a K-X, and I have been experimenting with some older K-mount lenses that I have. However, for one of the lenses, an SMC Pentax-M 1:3.5 24-35mm zoom, it takes fine photos in AV mode (with some exposure inaccuracy, which I believe is to be expected), but refuses to take any in Manual. I have set Aperture Ring to Permitted in the settings and have set up the Green button for stop-down metering, but the same thing still happens: the camera will raise the mirror, wait about a second, then click loudly as if taking a photo. However, no photo is ever registered as being taken. This happens the same regardless of what aperture or shutter speed I use.
Has anyone else had this experience with a lens, or know what might be causing it? I have successfully used a variety of old Pentax-M primes with this body without running into any problem like this.
10-31-2011, 02:22 AM   #2
Douglas_of_Sweden's Avatar
I've used the same lens on the K20D and the K-7 without problem. Not sure if I used it on the K-5 yet. But I don't own a K-x. Mostly I used this lens on film, where it is has a really handy focal range and an optical behavior which makes it reasonable to call it "three primes in one".
11-07-2011, 06:23 PM   #3
ChipB's Avatar
I don't have a K-X, but I do have a K20D and from your problem description, it sounds like the camera is going into 'live view' mode. Is the back LCD active? Now, as to why this would happen (or whatever it is that happens) with just this one M-series lens ???????? Assuming there's no camera problem, then I'd double check all the programable settings for the various buttons. All I can think of.
aperture, camera, k-x, lenses, mode, pentax help, pentax-m, photo
Pentax Q has manual control in video mode. :) LFLee Pentax Q 74 10-19-2011 07:50 AM
uncompromising alternative to pentax 35mm manual lens spacevoid8 Pentax Medium Format 12 09-19-2011 08:08 PM
Pentax ES II: Light meter does not work in a manual mode ? svn.ictus Pentax Film SLR Discussion 5 09-04-2011 06:47 PM
Pentax k-x hotshoe not working in manual mode crimespree Troubleshooting and Beginner Help 6 06-17-2011 05:52 PM
Pentax K100D stuck in manual mode LloydTifflin65 Pentax DSLR Discussion 2 04-20-2011 10:04 PM
All times are GMT -7. The time now is 11:36 AM. | See also: NikonForums.com, part of our network of photo forums!
