12-03-2011, 09:24 AM   #1
DanielK
Guest
unwanted switch to JPEG from RAW
Took alot of photos in RAW but maybe a third ended up as JPEGs. Thought it was me but found some that the camera switched to JPEG for a single photo and added 5 hours to when it was taken. I checked image number sequence and I was not at the same spot again so I could not have taken it then. Anyone have any ideas? Taken with a K 7. Thanks.
12-03-2011, 09:26 AM   #2
Wheatfield's Avatar
You didn't inadvertently switch over to green mode on the mode dial did you?
I can't help you with the clock setting. I've never had a problem with that.
12-03-2011, 11:42 AM   #3
Thanks for the response but no, I didn't change any settings with either dial or in menu. The switch was in the middle of several other photos.
12-03-2011, 03:10 PM   #4
Wheatfield's Avatar
Could you post an image (with exif intact) from one of the offending photos?
camera, jpeg, pentax help
[K10D RAW+]Exposure difference between RAW and JPEG sterretje Pentax DSLR Discussion 9 04-13-2010 02:06 AM
What do you use most Raw or Jpeg Ivo_Spohr Pentax DSLR Discussion 75 04-02-2010 09:04 PM
JPEG, RAW, JPEG + RAW...huh? Raptorman Troubleshooting and Beginner Help 14 12-22-2009 11:49 AM
RAW or JPEG tkcampbell Pentax DSLR Discussion 24 12-13-2009 04:31 PM
RAW + JPEG with JPEG on One Star quality laissezfaire Pentax DSLR Discussion 58 12-10-2008 02:42 PM
All times are GMT -7. The time now is 05:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
