12-30-2011, 01:56 AM   #1
Unregistered
Guest
flash exposure
having problems taking indoor photos with pentax 1dt ds using da 18-55lens to dark or to light with flash
12-30-2011, 05:13 AM   #2
You should register and then post some pictures with their exif data so we can help. You should also look at our article section for tips on exposure, as there's a lot of stuff involved in flash photography.
12-30-2011, 01:05 PM   #3
It would also help to know what brand/model flash you are using, and what camera/flash modes you are using (manual, auto, ttl, etc.).
For example, if you are using a Pentax p-ttl compatible flash, it should give pretty good exposures with no real problems. If, however, it is an older flash, or one that is not p-ttl capable, then the issues are more complicated.
As Adam suggested, register and post some photos, with exif data intact. Also post more detail about your equipment and what settings you are using.
camera, flash, pentax help
All times are GMT -7. The time now is 05:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
