01-17-2012, 09:45 AM   #1
Unregistered
Guest
PEF Format problems in lightroom
Just upgraded from K10 to K5.
I use Photoshop CS7 and lightroom 2-no problems with PEF format with K10.
But PEF format from K5 causing problems.
Lightroom not recognising and while I can download in Bridge photoshop not opening file.
DNG format not working either.
Any ideas- do I need to upgrade Photoshop?
Ha st ehPEF format changed?
Thanks
Roger
17 Jan 2012
01-17-2012, 10:44 AM   #2
Get all the free upgrades to your Adobe products that are available and try again. If that doesn't work, then try shooting DNG instead of PEF or use free Adobe DNG converter to convert to DNG before importing into LR.
01-17-2012, 11:36 AM   #3
Anvh's Avatar
You need lgithroom 3 for the K5 if you want to use PEF but you can just as well use DNG though, they are the same size now with the K5 and you can use the k5 DNG in lightroom 2 en photoshop 7.
CS7 isn't out yet, i believe they want to bring out CS6 this year
And yes PEF format is changed with each camera model like every other RAW file except DNG, so you need spcial support for the camera rather then the file itself.
01-17-2012, 11:42 AM   #4
DNG actually changes too, which is why the free converter asks what level of compatibility you want. I notice that my LR3 created DNGs (from PEFs) will not open in the Pentax SilkyPix utility...
01-17-2012, 07:26 PM   #5
Anvh's Avatar
Isn't DNG accepted as a standard yet, i know they have send it in for approvement several years ago?
Anyway DNG uses TIFF/EP for the actual imaging part so it should always be able to read that, it's hopefully only the extra data that might be missed.
01-18-2012, 10:11 AM   #6
Wheatfield's Avatar
It's in the programming that Pentax had SilkyPix do. The Pentax utility will only work with camera created DNGs.
01-19-2012, 02:26 AM   #7
Jasvox's Avatar
Shoot DNG. Keep it simple.
Jason
camera, format, k10, k5, lightroom, pef, pentax help, photoshop
Lightroom and Photoshop for K-5 .PEF files? BONSTA Pentax K-5 28 09-02-2013 01:40 PM
Aperture 3 and K5 .pef problems i83N Digital Processing, Software, and Printing 21 11-26-2010 12:55 AM
K-r PEF in Lightroom? Larsenio Pentax K-r 12 10-28-2010 02:49 PM
Lightroom v1.4 Update Problems with PEF mithrandir Digital Processing, Software, and Printing 4 03-17-2008 07:03 AM
Problems with PEF raw format on K10D unkbar Pentax DSLR Discussion 14 10-23-2007 03:15 PM
All times are GMT -7. The time now is 02:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
