02-10-2012, 09:54 AM   #1
Unregistered
Guest
External flash problem
Hi All
I have a K200d and a Sigma EF-530 DG ST flash and have had some success with it. In the caves at Cheddar Gorge I was able to get great photos of the flowstone and stalagmites etc. I have had trouble taking informal portriats at a retirement party and at a sales function where all the shots were underexposed. Retook some of these with the pop up flash and they were perfect.
Done tests at home and camera set to AUTO and flash to TTL results under exposed by approx 2 stops. Angle the head for a bounce shot and its nearly perfect. Fit a Stofen defusser and aim flash direct and it near perfect.
Tried the same with the camera set to P and Av with the same result. Read the section in the camera manual and the flash manual and can't see where I'm going wrong!!
Any help or suggestions gratefully received
Thanks
André
02-10-2012, 11:48 AM   #2
I don't know your flash at all, but are you aware that the K200D does not do TTL? P-TTL is not the same thing. I don't know if your flash is P-TTL capable.
02-10-2012, 07:47 PM   #3
I think the flash does support P-TTL, but if you set it to TTL (as opposed to P-TTL) then it won't work properly on your K200D.
Sigma EF-530 DG Super reviews - Pentax Camera Accessories: Database and Reviews
02-11-2012, 06:45 AM   #4
Well, Adam linked to the wrong flash (Super not ST), but he is right. Your model does support P-TTL as noted here: Sigma EF-530 DG ST reviews - Pentax Camera Accessories: Database and Reviews
If you go to the articles section of the site Accessory and Memory Articles - PentaxForums.com there are several articles that might have information to help you solve your problem.
02-12-2012, 05:57 AM   #5
Hi All
Thanks for the info it's much appreciated, The paperwork included witht he flash say it is PTTL but it only has 3 settings. TTL Full power and 1/16 power. Small print says Serial controlled TTL Auto zoom?? I'm beginning to suspect I got some good photos with this by pure blind luck!!
I've read all of the articles but as I'm relativly new to digital I'm still lost. Previous camera was a film K1000 so I could use it in manual mode as that is what I'm used to but it seems a shame to not take advantage of the features if possible.
Any ideas as to how to get this to work would be great or do I stick it on the Bay?
Thanks again
André
camera, flash, pentax help, perfect
External flash with kx ldmlkn Troubleshooting and Beginner Help 14 12-03-2011 03:00 PM
K-r uses too slow shutter times with external flash robroy Pentax K-r 19 08-23-2011 09:35 PM
external flash FIF-500ftz natethan Pentax DSLR Discussion 2 09-17-2010 05:28 AM
Generic external flash TeamPentax Troubleshooting and Beginner Help 9 09-11-2010 10:52 PM
Problem: external slave flash too early ? ZigDaPig Pentax DSLR Discussion 10 01-10-2008 02:21 PM
All times are GMT -7. The time now is 04:30 AM. | See also: NikonForums.com, part of our network of photo forums!
