02-20-2012, 10:00 AM   #1
Clarke Renard
Guest
radom picture are black no photo
I just bought a used Pentax K10D from a place in Canada called Henrys About every 40 or 50 photos taken the next few the shutter opens but no photo. I just learned today if I turn the camera off the problem go's away. I don't really want to go thru the Returning deal. Also the Card is formated to the camera, Is there any thing else I can do?? I'm NOT going take the camera apart. THat would be for me to do since I don't know what I'm doing. Thanks Clarke
02-20-2012, 10:19 AM   #2
ChipB's Avatar
Clarke, hard to say without pointing to a camera flaw - BUT, first thing to do is to try another SD card. They can go bad in weird and strange ways.
02-20-2012, 10:46 AM   #3
aleonx3's Avatar
try resetting the camera to default settings and try again and see if that changes. Also, notice if there is a pattern happening or not (meaning every 40 photos?). Does the camera hangs after that? and only goes away after you reset? Check the firmware of the camera etc.
02-20-2012, 03:49 PM   #4
Clarke Renard
Guest
RE Black photos
I checked each of the Black photos and by the way one of them was pink, anyway they all had reading like 1/350 F5,6 that was the pink one and the next two said 1/500 F6.7and then 1/350 F6.7+ they all had the ISO100 and jpeg in the upper left and the camera was in the P mode. so it acts like there a photo there. My hobby is trains & birds. this is what i've been photographing for the past weekend. and before that 35 yrs on the trains. after the first time it was 23 photos 2 black and 1 pink then after 66 photos 1 black so theres no repitition as to when the black photos happin the last time it happin I turned the camera off then back on and it was fine. pretty neat problem... Again I hope not to return this camera, being that it came from Canada. from what I hear Henrys is a big name up there..
02-20-2012, 05:24 PM   #5
aleonx3's Avatar
QuoteOriginally posted by Clarke Renard Quote
So, based on what you described, it appears that the camera did not freeze, just mysteriously way under-expose the 'black' photos. What are the exposure settings for the ones that are okay? Compare them to see if there are any difference; also did the P mode stay up all the time? My experience with the k10 was that sometimes I accidentally knock off the mode dial (changed to something else). That is the reason why the mode dial 'lock' mechanism was introduced in k-7 and k-5 now. Try to use other modes (other than P) to see if the same pattern appears.... may be you can find the answer from there.
camera, pentax help, photo
Black Spec on Photo macca809 Troubleshooting and Beginner Help 3 09-02-2011 04:54 PM
Misc Photo of the Week - Black Cat Adam Post Your Photos! 4 08-19-2011 06:37 AM
Need to add black to make the picture more realistic ? TanGU Pentax SLR Lens Discussion 11 12-22-2010 11:21 AM
What happened when you get a black picture? theteerex Pentax DSLR Discussion 16 11-21-2010 02:11 PM
Misc Radom Air Show 2009: Red Arrows, Midnight Hawks WoRaS Post Your Photos! 2 10-05-2009 05:24 AM
All times are GMT -7. The time now is 03:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
