Originally posted by Tylos Hi All,
Thanks for your responses.
Parallax is correct, I set the camera to enable the camera to be used with the lens aperture ring in use and now when I take shots using the aperture ring the exposure is OK at all aperture settings in the AUTO PIC mode.
Actually, while they might be of appropriate brightness, when you use the aperture ring in any mode but M, it is completely ignored, and only shoots wide open. read the sticky note at the front of Beginner's forum for more on how to use manual lenses (which your lens becomes when you use the aperture rong).
So what you are seeing is indeed consistent with sticky blades – shots come out good when shooting wide open, overexposed otherwise.
