04-04-2012, 06:41 AM   #1
Anthony
Guest
K10D Autofocus Motor
Hi,
My K10D stopped working while shooting today. The autofocus motor just stopped. Focus confirmation is still working.
At the same time I noticed that "MF" was displayed in the viewfinder- putting the switch to MF and back to AF-S or AF-C does nothing. Also the LCD screen indicates that exposure bracketing is turned on from 0 to +2.5... I wasn't using bracketing at the time.
Finally regardless of what lens is inserted the camera asks for the focal length (for shake reduction)- as if an old manual focus lens was being used.
Firmware is the latest version.
Has anyone encountered something like this before?
Thanks for any info
04-04-2012, 06:57 AM   #2
topace's Avatar
Hello,
Ignoring the bracketing thing, It sounds like the camera is unable to identify the lens. It won't autofocus a lens it doesn't recognize.
My guess is the connectors on either the camera or the lens mount give a bad connection. Question is what to do about it.
I had this, and some other problems including inability to step down lenses when the K-mount on my K-10D was in the process of breaking. Finally, the mount broke totally and I had to say goodbye to it.
Be careful if screwing/unscrewing the mount for tightening, or for exploratory surgery. They screw into plastic and not metal (As far as I can tell, this is true for all K-mount DSLRs), and using a little too much force will turn your K-10D into mine.
04-04-2012, 07:01 AM   #3
eddie1960's Avatar
you might also try cleaning the contacts before doing anything else (on both the lens and the body) this happens occasionally when the contacts get dirty/lightly oxidized as well (before fiddling with screws etc)
04-04-2012, 12:03 PM   #4
Anthony
Guest
Thanks guys, I can't see anything wrong with the contacts or anything else for that matter. Looks like it's junk now...
04-04-2012, 12:37 PM   #5
eddie1960's Avatar
Given the resale on them now it's probably not worth a repair unless it's cheap (ie under say $200) you can pick up a used one from 225-300 depending on condition and # of actuations)
If you have the cash of course the K5 is a really nice jump (I have the K7 and it was a big jump from the K10)
Edit:
Or if everything else is fine slap an EEs screen in it and make it a dedicated Manual Focus camera
04-05-2012, 12:32 AM   #6
topace's Avatar
I actually missed my K10D despite buying the K20D to replace it. The K20D just felt noisier and the colors were not quite as vivid. I hear the K-7 was much like it. But when I got my K-5, I forgot all about it. So for an upgrade, I think it's clear what you'd want.
autofocus, camera, focus, k10d, k10d autofocus, lens, motor, pentax help, time
K10D won't autofocus camel58 Troubleshooting and Beginner Help 4 06-08-2011 07:54 AM
Autofocus motor. NecroticSoldier Troubleshooting and Beginner Help 6 03-19-2010 08:02 AM
Two DA Autofocus Motor Failures! iflyfisher Pentax SLR Lens Discussion 22 12-08-2009 02:51 PM
How noisy is the K10D's autofocus? Slideshowmike Pentax DSLR Discussion 4 12-02-2006 05:39 PM
All times are GMT -7. The time now is 08:59 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
