05-30-2012, 06:03 AM   #1
NAMITA
Guest
White balance
Does white balance affect exposure? I read that photosites are color blind in absence of bayers array. when intensity of light isnt changing, an object should look same in greyscale even when whitebalance changed.
05-30-2012, 07:11 AM   #2
enoeske's Avatar
I believe that in jpeg mode, it does but it doesn't in when shooting raw. If you have the white balance set very warm and orangey, then your red channel will probably blow out first before the others. In jpeg mode, that clipped data is gone.
05-30-2012, 10:39 AM   #3
Pictures saved in raw are not modified by the actual WB settings. But the data appended contain these settings (so they can be used when transforming off camera to jpg later, if wanted). And the display on the back of the camera also uses them (including LV?). If the dynamic range is big enough, you maybe able to avoid clipping (by correcting in or out of camera), but not so often if you save as jpg only.
06-21-2012, 03:23 PM   #4
zekewhipper's Avatar
WB and exposure are separate things.
balance, camera, pentax help
And yet another white balance question. magnum1 Troubleshooting and Beginner Help 7 10-08-2010 07:26 AM
White balance fekish Troubleshooting and Beginner Help 24 10-06-2010 06:31 PM
White Balance on K7 eccs19 Troubleshooting and Beginner Help 6 10-05-2010 09:43 AM
Help Me Understand White Balance jaieger Troubleshooting and Beginner Help 22 08-08-2010 07:13 PM
Auto white balance vs. daylight balance outdoors. fevbusch Pentax DSLR Discussion 7 02-18-2007 03:04 PM
All times are GMT -7. The time now is 09:32 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
