06-12-2012, 06:02 PM   #1
ron paterson
Guest
Lens AF330FTZ on K -x Camera
Can anybody give me a tip to get best use of AF330ftz flash on K x Camera body.
Thanks
06-12-2012, 06:19 PM   #2
twitch's Avatar
It's use is very restricted on the K-x, seems like it's manual only (as the K-x does not support TTL only p-TTL) and even then you only have a choice in power between 1/16 and 1/1.
06-12-2012, 08:18 PM - 1 Like   #3
demp10's Avatar
You will have to use it in manual mode, either MH (full output) or ML (1/4 output). An interesting twist is that you can control the output also by using its zoom settings. If your lens is 55mm or longer, any zoom setting (28, 35, 50, 70, 85) can be used and it will cover the field of view of the lens. With shorter lenses you will see vignetting at longer zooms.
In full mode (MH) you get for ISO 100 these guide numbers in meters: 20 (@28mm), 24 (@35mm), 28 (@ 50mm), 31 (@70mm) and 33 (@85mm)
In low mode (ML) you get: 5, 6, 7, 7.8 and 8.3 respectively.
You can calculate the correct Guide number (subject distance / F-stop) and then from that the proper zoom setting.
Another way to use the flash in "Auto" mode, it to leave it in TTL mode. It will always fire at full output. If you use an F, FA or DA lens, in Av mode, it will communicate with the flash and set the proper zoom setting. It will also display the effective distance of the flash for the selected f-stop in the camera and the ISO value. You can keep changing the f-stop until the maximum distance is approximately the same as the subject-to-flash distance and the exposure will be correct.
af330ftz, camera, pentax help
Camera or lens? sherib Pentax DSLR Discussion 14 11-29-2010 08:04 PM
AF330FTZ flash joshnl Flashes, Lighting, and Studio 1 07-23-2010 05:55 PM
af330ftz and af500ftz pz1 Pentax Camera and Field Accessories 2 04-11-2010 12:14 AM
For Sale - Sold: FS/FA: Sigma 55-200mm, Pentax AF330FTZ dleung Sold Items 1 02-18-2007 04:03 PM
All times are GMT -7. The time now is 02:52 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
