06-19-2012, 01:36 AM   #1
ALANBAILEY
Guest
Display flashes red
I have a Pentax k200. At times when I review shots on the lcd display. some areas. those large areas of the same colour
e,g,a blank sky flash red.
06-19-2012, 01:40 AM   #2
That means those areas are overexposed. Try using bracketing or exposure compensation, or matrix metering to fix the issue. You can also disable the warning in the playback menu if you want.
Basically, it means that those areas have no detail in them whatsoever, so the final product may look worse than you'd like it to look as a result.
06-21-2012, 10:00 AM   #3
Marc Sabatella's Avatar
You can turn off that warning too - just consult your manual, look for something like "exposure warning"
06-21-2012, 11:50 AM   #4
bluenose's Avatar
Manual, page 172, "Setting the Playback Display"
1. Set [Playback Display] in the [→Playback] Menu.
2. Press the four-way controller (→).
3. Use the four-way controller (←→) to select On or Off
Hope this helps.
Regards
camera, display, pentax help, red
K-5 display cacaueiro Pentax K-5 4 02-16-2012 08:39 PM
Red display on K-x Live View Lloyd Troubleshooting and Beginner Help 4 10-17-2010 07:23 PM
Turning off the display Relic Pentax DSLR Discussion 2 09-09-2010 10:09 AM
K-7 display not dustproof? amaurosis Pentax DSLR Discussion 6 07-31-2010 10:42 AM
What other camera co's flashes can use the same addons as my Pentax flashes? Grimlock Flashes, Lighting, and Studio 3 08-22-2008 05:39 PM
All times are GMT -7. The time now is 07:16 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
