07-12-2012, 07:43 AM   #1
Sarah N
Guest
Inputting focal length of vintage lens to K100D
Help! I have a K100D and have only recently begun experimenting with older lenses that I used with a K1000. I have a K mount Vivitar 100-300 zoom that I'd like to use, but am confused about focal length. When I set the K100D up to use this lens and I see the screen for inputting focal length, what number should I select? Is there just one number to use in this situation, or do I have to go back into the menu and re-select each time I change how far in I'm trying to zoom? Hoping there's a quick and simple answer to this question, as I'm leaving soon on vacation and want to do some wildlife photography. Thanks for any help!
07-12-2012, 07:51 AM   #2
You can just select the lower end of the range. You'll get worse performance at 300mm, but at least none of your photos will have SR-induced blur
camera, help, k100d, length, lens, pentax help
Inputting focal length? slackercruster Pentax DSLR Discussion 14 02-08-2012 02:26 AM
K100D Focal length input problem newarts Troubleshooting and Beginner Help 3 09-13-2011 03:07 PM
Inputting focal length of a variable lens on my K-x. / Shake reduction problems? TexasLangGenius Pentax DSLR Discussion 7 11-26-2010 11:35 PM
K100D focal length report with SR Andi Lo Pentax DSLR Discussion 9 08-19-2009 10:20 PM
K100D: What focal length to enter? newarts Pentax SLR Lens Discussion 8 12-28-2008 11:33 PM
All times are GMT -7. The time now is 07:50 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
