07-21-2012, 12:37 PM   #1
William Bane
Guest
Lens Fit
Will the lens from a Petri FT fit my Pentax Kr?
07-21-2012, 02:19 PM   #2
Canada_Rockies's Avatar
I doubt it very much. For one thing the Petri was a half-frame camera, so you would have horrible vignetting (your K-R is 2/3 frame = larger). I also vaguely remember that the mount register (distance from mount to film/sensor) is considerably shorter.
07-21-2012, 02:21 PM   #3
If the FT lens is a screw mount (M42) then yes it will work. I know that they did have a period of m42 mounts and later bayonet type mount. The bayonet versions will not work unless you modify it. As for the M42 versions you will need an M42 adapter for it to work. It is not compatible straight out of the box.
07-21-2012, 02:25 PM   #4
Talisker's Avatar
What model of FT? The original FTs used a proprietary bayonet that won't fit. The later models from the mid-late 70s that I can remember used the 42mm screw thread that will fit via a converter, albeit with no aperture control. I think the final model before they went bust was a K bayonet, but that wasn't an FT. The question is, why would you want to?
07-21-2012, 02:40 PM   #5
Talisker's Avatar
QuoteOriginally posted by Canada_Rockies Quote
I don't think any of the SLRs were half frame, just some fixed lens compacts.
camera, lens, pentax help
will kx lens fit on k5 clippo Pentax SLR Lens Discussion 7 08-22-2011 12:58 PM
So I need a 47mm lens hood to fit my 50mm lens? lovemehate Troubleshooting and Beginner Help 15 04-18-2011 12:51 AM
will the lens fit? kschmitt Troubleshooting and Beginner Help 4 01-12-2011 09:09 PM
Will this lens fit Pentax K-x newyorker Pentax DSLR Discussion 26 10-04-2010 01:23 PM
Will this lens fit my kx ??????? spanky66d Troubleshooting and Beginner Help 7 02-18-2010 03:23 PM
All times are GMT -7. The time now is 04:19 PM. | See also: NikonForums.com, part of our network of photo forums!
