07-31-2012, 07:39 AM   #1
James Moritz
Guest
Will my old lenses work with a K-5 body?
I am thinking of getting a Pentax K-5 and would like to know if my old lenses will work. I currently use a Sears KS500 camera (film not digital) with fotomat series lenses. These lenses use a Pentax K mount. I think the camera and lenses were made by Konica for Sears back in the 80's. My camera is manual focus and none of my lenses have an "A" setting on the inner ring. My lenses are 50mm, 135mm, and 75-200mm zoom/macro.
07-31-2012, 07:45 AM   #2
boriscleto's Avatar
The camera and lenses were made by Ricoh, who now owns Pentax, not Konica.
That said, yes the lenses will work with a K-5 with a few caveats. They will only work in M mode with stop down metering or wide open in AV mode.
https://www.pentaxforums.com/forums/pentax-beginners-corner-q/110658-using-ma...x-dslrs-f.html
07-31-2012, 07:50 AM   #3
topace's Avatar
For pentax K lenses without the "A"-setting, there's the caveat that you cannot measure the exposure without stepping down (you can shoot open with Aperture Priority or set it to M and press the green button for measuring.). Also note of course the 1.5x crop factor (Your 50 is now a short tele). Other than that, they work just fine.
I have a few old lenses (K and M42s), and used to use them quite a lot on my digital bodies, including the K-5, with technically good results (can't blame the camera ;-) )
07-31-2012, 09:28 AM   #4
You may face with the Ricoh pin issue...check the forum...if you have such pin on your lenses it has to be removed, otherwise the lens will stuck on your camera..then you will have a real issue...
some link among the tons of available in internet...
theatre of noise: Ricoh Lenses On Pentax Cameras -- The Ricoh Pin Fix
07-31-2012, 10:11 AM   #5
boriscleto's Avatar
QuoteOriginally posted by Vasyl Quote
Not likely as the OP says they don't have an A (P) setting. The KS500 (Ricoh XR500) pre-dates the XR-P.
07-31-2012, 11:35 AM   #6
QuoteOriginally posted by boriscleto Quote
Agree, but it is not about the body, but the lenses.
08-01-2012, 07:50 PM   #7
James Moritz
Guest
Thank you
Thank you for all your replies you have been very helpful.
camera, k-5, lenses, pentax, pentax help, sears
will these lenses work for me rx2man Pentax K-5 12 11-03-2011 09:16 AM
Why do DA* lenses work on PZ-1p? blackcloudbrew Pentax SLR Lens Discussion 6 09-16-2011 10:17 AM
chinon body + pentax flash - will it work? xneon Flashes, Lighting, and Studio 5 06-28-2011 07:32 AM
List of lenses that work on K7? rena Pentax SLR Lens Discussion 8 02-20-2011 06:01 PM
Which prime lenses would work well? Vantage-Point Photographic Technique 9 11-08-2010 12:38 PM
All times are GMT -7. The time now is 09:45 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
