08-08-2012, 08:54 PM   #1
Hollon
Guest
WG-1 issue
I just bought a new WG-1 and on the second use...first time in the water, the focus assist/self timer light wont go off.Even when the camera is turned off, it stays on. I thought I would try removing the battery, and when I did, I noticed there was a small amount of water in there. This doesnt bode well I am thinking. Is it a short turning the light on, or do I have an incorrect setting?
02-27-2013, 09:52 AM   #2
andrew88
Guest
same problem
I just bought my wg-1 and on the first use, took it into the water, just floating along the surface taking videos of turtles. It was a ton of fun but i noticed some steam on the screen and later the lens after I got on the boat. i took the battery out and let everything sit open so it could dry out. waited a few hours and continued taking pictures on land but they were all pretty much garbage as they had a slight fog to them. now, the red light on the front of the camera near where it says "adventure proof", hah, is constantly flickering, even when the camera is off. The camera turns on and i can go through all the functions but when i go to use the automatic mode, it wont take a picture. probably because it needs to use the flash and that got messed up.
i didnt even go deep so im wondering if i did something wrong or if the camera is bunk?
amanseth88@gmail.com if you have any solutions
02-07-2014, 10:12 PM   #3
timmytation
Guest
timer light stays on even when the camera is off
Same thing happened to my WG-1. The timer light won't go off even when the camera has been turned off. I tried removing the battery then putting it back on but the orange light is still on. What to do? How do you turn it off? It might discharge the battery if I leve the battery inside. Please help. Thanks
02-11-2014, 07:19 PM   #4
Did you try taking the battery out and reinserting.
02-24-2014, 04:24 PM   #5
If these are very new, I would send them back to the place you bought them, or send them to Pentax and ask for a replacement....that just shouldn't happen, but there are always a lemon or two....
camera, light, pentax help, water, wg-1
Vivitar MC Tele Converter 2X PK-A/R-PK issue...or no issue? WiseOx Pentax SLR Lens Discussion 7 12-15-2019 05:53 AM
K-5 AF Issue stormtech Pentax K-5 44 05-30-2012 03:53 AM
is this a FF issue costas60 Pentax K-r 18 07-15-2011 04:28 PM
kr ff issue kr newbie Pentax K-r 29 06-26-2011 11:29 AM
FF Issue? rockyram Pentax K-5 6 04-15-2011 06:11 PM
All times are GMT -7. The time now is 07:00 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
