Originally posted by Joe Rice I believe that I am following the instructions on pages 208-209 to manually set the white balance. But everytime I press the shutter relaese a picture is taken contrary to the memo on page 209. What am I doing incorrectly? Thanks in advance for all responses.
Starting with the general WB settings: With the camera turned on and your lens cap removed, press the < arrow on the 4 way controller. The white balace settings will appear and you should be able to see the changes they make as you scroll through them. When you find one you like, press OK, and the camera will use that setting. You should not be pressing the shutter release, though you can turn the power on one setting further to the circular icon to take a shot that will also let you see how the different settings change the white balance.
One other option is press the < button while in live view, which will also show the effects of changing the settings.
Moving on to Fine Tuning WB: Fine tuning is similar, only you can use the arrow controllers to change the color balance. Make sure when you hold your camera up to a white surface, you press the sutter button down and hold it until a picture appears on the screen. Then make any changes you wish to make with the arrow keys. Press OK when you are done, until you are back to start. No picture is saved when you do this.
