09-17-2012, 06:12 AM   #1
CPS
Guest
Attaching 43mm filter to 21mm lens hood
I've read several other users' comments re: attaching a 43 mm UV filter to the 21 mm lens hood and for some reason, I still can't figure out how to do it. Does anyone have a picture or illustration of the UV filter attached to the inside of the lens hood--which is what I understand to be the way to do this...Maybe that is incorrect.
09-17-2012, 06:21 AM   #2
Blue's Avatar
The hood comes off. It uses a bayonet system to mount it. look inside the hood after taking it off. The filter screws into the inside of the hood.
09-17-2012, 10:13 AM   #3
CPS
Guest
I've tried doing that several times and the hood acts like it will thread, but instead just turns and turns and turns without ever tightening. This is for the pancake lens. Can it handle both the hood and the filter?
09-17-2012, 02:39 PM   #4
jatrax's Avatar
Does your filter have threads on both sides? Not all do. And since it needs threaded into the hood you need female threads on the front of the filter.
09-17-2012, 03:16 PM   #5
Blue's Avatar
QuoteOriginally posted by CPS Quote
As Jatrax said, the filter screws into the back side of the hood via the female threads. The hood must be removed from the lens to do this.
09-17-2012, 09:28 PM   #6
mikeSF's Avatar
im more interested in where you actually found a 43mm filter?!
09-17-2012, 09:29 PM   #7
Blue's Avatar
QuoteOriginally posted by mikeSF Quote
B+W makes them. BH has several different B+W including this one.
http://www.bhphotovideo.com/c/product/120402-REG/B_W_66023185_43mm_UV_Haze_010.html
09-20-2012, 02:02 AM   #8
steve1307's Avatar
Just wondering if a polariser (which is thicker framed) would fit under there?
Anyway proabably its pointles and not practical because it could not be adjusted with the hood on.
I've used this lens a lot lately with a normal 49mm C-POL sans the hood of course.
camera, filter, hood, lens, mm, pentax help, uv
FA 43mm filter & hood rpark71 Pentax SLR Lens Discussion 60 04-17-2011 04:18 AM
For Sale - Sold: 43mm Hoya HMC UV Filter (fits DA 21mm Ltd.) (US) deadwolfbones Sold Items 2 07-15-2010 07:02 AM
For Sale - Sold: DA 21mm F3.2 Limited(+ Hoya mcuv 43mm filter) (US) Lariya Sold Items 4 03-17-2010 12:09 PM
DA 21mm + UV filter + lens hood -- help me? gemini Pentax SLR Lens Discussion 14 02-03-2009 02:02 AM
Attaching filter on film lens, is it usefull? kyrios Pentax SLR Lens Discussion 4 04-09-2007 01:12 AM
All times are GMT -7. The time now is 04:17 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
