10-31-2012, 06:48 PM   #1
Mitch1234n9r
Guest
K10D problem, and I need help
I have a K10D and normally I use it on the manual setting or the aperture control setting. Now I find that it is permanently on the aperture setting no matter what setting I choose.....manual, shutter, automatic...whatever setting. And in the top window, while I can see the shutter speed, the aperture reading is always just a series of dashes....no indication of what the aperture actually is. I have recently moved locations, and in the packing have lost the user manual, so it is difficult to check to see if I have accidentally done something to the settings to cause his. Or does it sound like a computer problem that will require sending it to a camera clinic?
10-31-2012, 06:58 PM   #2
Is your aperture ring not set to "A"?
10-31-2012, 08:30 PM   #3
Mitch1234
Guest
Der....
Thanks....how thick am I? Very thick........ It wasn't. Now it is. :-))))))
10-31-2012, 11:12 PM   #4
Glad that fixed the problem! Sometimes even the obvious things can be overlooked
10-31-2012, 11:56 PM   #5
newmikey's Avatar
QuoteOriginally posted by Mitch1234 Quote
It happens and just recently I answered in another thread on this forum with these words:
QuoteOriginally posted by newmikey Quote
I second that and would add: don't even try being embarrassed about it! We've all been there and anyone who says he hasn't is lying through his teeth I've still got some scars on my forehead from slapping it so much!
So, welcome to the club!
11-01-2012, 09:04 AM   #6
ivan vernon
Guest
Mr.
You can get a K10 (or any Pentax camera) manual from the official Pentax site. You can print out asll 218 pages, punch holes, and set up with tabs in a 3-ring binder. That is what I have done, and now I can sit down in my camera work area in the basement, read the manual, play with the camera chapter by chapter, and entertain myself when I am not staring admiringly at my silver 77 mm limited lens.
11-01-2012, 05:46 PM   #7
Mitch1234
Guest
Thanks, guys. I had a stroke some time ago and have almost lost the use of my right hand, and occasionally it can do what I don't want it to do...like move the aperture ring etc.....
11-01-2012, 06:34 PM   #8
I find it easier and quicker to post my questions online than to use the manual! These forums are totally awesome.
11-02-2012, 07:59 PM   #9
ivanvernon's Avatar
But if you have the manual set up with tabs for quick reference, you can be an expert and answer other members' questions! :>)
01-08-2013, 06:24 PM   #10
But if you don't want to print the entire manual (lots of paper), I found that opening the file (and perhaps scrolling) was quicker after I saved it to my computer, rather than going to the website each time I wanted to look something up. (Maybe everyone has done this?)
Peter
01-08-2013, 08:55 PM   #11
ivanvernon's Avatar
QuoteOriginally posted by PeterChris Quote
Peter
Yes, that would help save a tree, but I do enjoy having the paper copy to pore over.
01-09-2013, 07:25 PM   #12
With the PDF Manual file open by pressing Ctrl + F (PC) you activate the find function, type in your search word and it will highlight the word in a Back, Next way through the manual. Handy when the same word (e.g. Aperture or Flash) occurs under different headings, you'll find all the references to it.
Chris
aperture, camera, k10d, pentax help, shutter
K10D Problem with Mirror? sb in ak Troubleshooting and Beginner Help 4 08-22-2012 09:56 PM
Metering problem - K10D KayTen Pentax DSLR Discussion 8 09-28-2011 10:06 AM
K10D problem? GordonZA Pentax DSLR Discussion 6 06-27-2011 09:37 PM
1st Problem ever on my K10D from new waddojohn Troubleshooting and Beginner Help 16 01-12-2011 05:02 AM
K10D AF Problem? Relic Pentax DSLR Discussion 4 12-13-2010 05:54 PM
All times are GMT -7. The time now is 08:53 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
