01-02-2013, 09:36 PM   #1
Rick from Tasmania
Guest
Pentax X90 shutter lag for action shots
I'm a newbie and I want to take sports/action shots but I miss the shot I want because the camera takes a moment take the pic when the shutter button is pressed. I must have it on wrong settings... or can it be saved to internal memory instead of card for quicker results?
01-02-2013, 09:42 PM   #2
LeDave's Avatar
Your shutter speed is too slow, the simple solution is to shoot in shutter speed priority and set the shutter speed numbers higher until you can see it freezing action.
01-02-2013, 10:39 PM   #3
QuoteOriginally posted by Rick from Tasmania Quote
I'm afraid the X-5 does have a bit of shutter lag out of the box, but if you make sure the focus is locked ahead of time, then you'll be able to get the shot faster. The SD card doesn't have anything to do with shutter lag, so I wouldn't worry about that.
01-16-2013, 10:23 PM   #4
Rick from Tasmania
Guest
Thanks for your replies. Setting it to shutter priority seems to do the trick. Cheers.
camera, pentax help, shots, shutter
Best autofocus point for action shots jwcjrccc Pentax K-r 11 07-21-2016 10:55 PM
Q Shutter Lag? emergo Pentax Q 7 08-17-2012 07:43 AM
Pentax DSLR Shutter Lag geekette Pentax DSLR Discussion 11 04-13-2012 09:54 AM
Which lens is best for action shots? DeliaRana Troubleshooting and Beginner Help 10 01-14-2012 03:40 PM
Pentax no good for action shots PePe Pentax DSLR Discussion 19 08-11-2009 12:14 PM
All times are GMT -7. The time now is 03:40 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
