01-18-2013, 03:33 PM   #1
rhmacman
Guest
New to K7
I have a K7 that works find in manual mode but when I switch to Green Mode which I assume is the same as auto
on a NIkon the settings are always 8000 and F29. How do I change this. When I change to Live View the settings
are correct. Thanks for any help.
01-18-2013, 11:28 PM   #2
What lens are you using?
02-08-2013, 09:40 AM   #3
This may have no effect on your specific issue, but if you are new to the k7 I am assuming you purchased it used. If this is they case, I recomend you reset camera to its default settings. The learning process will go more smoothly as a result. The manual will show you how to do this.
03-02-2013, 03:19 AM   #4
Also install the last firmware could be helpful.
camera, change, k7, mode, pentax help, settings
new to k7 ?? DaBaseballGuy Pentax DSLR Discussion 11 01-30-2011 07:13 PM
Hola! new to K7 here in Andalucia, Spain S0l Welcomes and Introductions 4 01-11-2011 06:15 PM
problem installing new new firmware to K7. jamescp Pentax DSLR Discussion 4 08-11-2010 11:41 AM
Brand new K7 with 272 shutter actuations according to Photome? allill Pentax DSLR Discussion 9 12-10-2009 06:27 PM
To K7 or not to K7 shutterbug71 Pentax DSLR Discussion 9 08-14-2009 04:13 PM
All times are GMT -7. The time now is 01:19 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
