02-15-2013, 06:29 PM   #1
John U
Guest
Focus on Image Not at Centre of Frame
Hi. I'm new to digital photography, and have recently purchased a K-r. I find it OK, but am sure I'm not getting the most from the camera due to my lack of knowledge. I don't find the manual the easiest to follow, and have some real billy-basic questions I'd like to ask... I'll do them one at a time so as not to cheese you off too much. My first one is: How do I focus on an image that is not in the centre of the viewing frame? I'm being told I can change the focal position but I don't seem to be able to.
Any help gratefully received!
Many thanks,
John.
02-16-2013, 04:38 AM   #2
Hi John
I'm pretty new to the DSLR world myself and shoot a K-5.
The method I mostly use, and I'm pretty sure would work the same on the K-r, is to position the centre of your viewfinder on what you wish to focus on.
Then half press the shutter to focus, and maintain the half press on the shutter.
This will hold the point of focus until you either fully press to take the photo or release the half press of the shutter.
So, while you are maintaining the half press you can then re-compose the framing so it is what you are looking for, then fully press the shutter to take the shot.
There are other things you can do also, I imagine someone else will expand on those.
Hope that made sense?
Cheers
Dean
02-18-2013, 12:35 AM   #3
There is also a SEL focus mode where you can choose which of the 11 AF points will be used via the 4 way pad.
02-19-2013, 08:29 AM   #4
I've never experimented with the 11 AF points that the K-r offers, but I use the same technique that Dean offered above. Not sure about the K-r, but I know Canon's 60D and 5DMKII's focus points, other than the center point, aren't the most accurate. Never bothered trying with the K-r just from past experiences.
02-19-2013, 11:27 AM   #5
QuoteOriginally posted by jbuck92 Quote
The K-r has a 3x3 matrix of points as well as one point to the left and one point to the right of that matrix. The 9 points within the matrix are all the same (cross-type) so they should work fine when selected.
camera, centre, focus, frame, image, pentax help
Image rotation when reviewing image. Worked on K7 but not K5? crossover37 Pentax K-5 & K-5 II 23 11-21-2012 09:32 PM
Setting centre focus point in green mode NogBoy13 Pentax K-5 & K-5 II 12 07-28-2011 06:50 AM
Left side of frame out of focus? K10D senojjj Pentax DSLR Discussion 5 09-29-2010 06:13 PM
Some part of my image does not appear on focus, How can i get it all in focus? rustynail925 Photographic Technique 11 09-08-2010 07:24 AM
SMC-M 50/1.4: focus in viewfinder and focus on frame don't match kerey Pentax SLR Lens Discussion 7 11-15-2007 09:07 PM
All times are GMT -7. The time now is 01:38 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
