02-16-2013, 11:52 AM   #1
Unregistered
Guest
Auto Focus Problem
Outdoors seems to work fine, but indoors when the shutter button is pressed at the 1/2 way point to focus the lens goes in and out continuosly before finally taking the picture.. by then its tooo late. What could be the problem? I've got a battery problem solved by changing to the eneloop batteries. But can't seem to fix the Focussing....
02-16-2013, 12:33 PM   #2
Tom S.'s Avatar
Please tell us what camera and lens you are using!
02-17-2013, 07:57 PM   #3
I am using a Pentax ist dl with 2 different lenses a Pentax18-55 and a Tamron28-200 .. they both do it..
02-17-2013, 08:24 PM   #4
The AF system on the ist DL isn't very advanced, and combined with slow lenses such as the two zooms above, you can expect a lot of hunting in low light.
I'd recommend upgrading to something newer such as the K-30.
02-17-2013, 08:55 PM   #5
I had a DL and still have a DS.
In reasonable light ( even in an ordinarily lit room) I would have to say the focus on those old cameras is faster and just as accurate as the K-01.
They do not hunt either. In low light they buzz the flash, in very low light like a TV room the AF does not work and they hunt.
I would suggest to put the 18~55mm on, set the camera to manual focus ( switch is on the left side near the lens) and using the focus ring, outdoors, focus and see if you get a red flash then a green confirmation dot at the bottom of the VF.
If that works, take the lens off and make sure the screw jack coupler ( near the AF/MF switch) moves in and out when you move the switch between the 2 positions.
02-28-2013, 12:56 PM   #6
QuoteOriginally posted by wombat2go Quote
My ist dl does do the 'buzz flash' keeps doing it I miss so many photos! It never did it when it was newer...
02-28-2013, 01:04 PM   #7
ok.. I tried outside and using the MF I do not get any kind of a red flash, but the green light at the bottom does come on... Don't know what I'm looking for on the screw jack coupler, but there is a tiny screw that moves when I switch the MF AF switch..
auto focus, camera, focus, pentax help
Pentax K5 Auto Focus Problem Dobson Troubleshooting and Beginner Help 7 01-14-2013 04:46 AM
Auto-focus problem with beloved k-10 PC_pentax Pentax DSLR Discussion 5 01-18-2012 04:53 AM
auto/manual focus problem ndarby1 Troubleshooting and Beginner Help 6 12-10-2011 02:00 PM
Auto focus/fungus problem? ripit Pentax SLR Lens Discussion 2 09-24-2011 10:01 PM
DA 70 f2.4 auto focus problem syain Troubleshooting and Beginner Help 7 08-30-2011 09:20 AM
All times are GMT -7. The time now is 08:31 PM. | See also: NikonForums.com, part of our network of photo forums!
