02-20-2013, 07:20 AM   #1
Bill Ski
Guest
K10D LCD Replacement
Any tips on replacing LCD on a K10D Dropped my camera and LCD looks like a broken window when turned on with no picture or information.
02-20-2013, 08:48 AM   #2
Pauld's Avatar
Honestly it would be a lot cheaper and easier replacing the camera then trying to repair it. You can find K10/K20 bodies fairly cheap in the marketplace these days.
03-02-2013, 03:18 AM   #3
Well, when you have new LCD, with disassembly instruction(rather easy to find) it shouldn't be a big problem to replace it. If you do something wrong sell demaged camera and have couple of $ from it.
09-09-2013, 06:27 PM   #4
wgroves
Guest
kd10
Flash problem with kd10. I have a dedicated flash for the camera,(pentax 360) however when I take the picture it appears it does not have enough light. The pictures come out black and yellow. the flash did fire, but the picture comes out the same.
The flash system in the camera set at 0.0/ I have changed the aperture and the sensitivity but the problem exists
09-10-2013, 12:04 AM   #5
QuoteOriginally posted by wgroves Quote
You should start a new thread with some samples (make sure that all EXIF info is intact) so that we can take a look and hopefully figure out the problem
02-24-2014, 04:41 PM   #6
For he OP - it would be cheaper and easier to find a replacement camera - DSLR are kind of tricky taking apart. Lucky for you, if the top lcd is working, then you can set your settings, and maybe get a remote trigger and use it as a time-lapse camera.
For the other poster, it sounds like you have not synced the shutter speed with the flash. Do you have it in PTTL? What is your shutter speed? Is the camera reading the flash? It may fire, but it may not be giving the data. first simple check, press the light button for the top LCD - does the flash light up?
camera, k10d, lcd, pentax help
LCD screen replacement part? Eruditass Pentax DSLR Discussion 2 01-29-2012 08:08 PM
K100D LCD window replacement erablesycomore Pentax DSLR Discussion 1 01-02-2012 04:35 PM
For Sale - Sold: Replacement LCD window for the K20D dgaies Sold Items 3 07-31-2011 08:37 PM
K10D Rear LCD Problem cajun0518 Troubleshooting and Beginner Help 6 07-08-2011 09:57 AM
Top LCD replacement on *istD Giga_Def Pentax DSLR Discussion 6 02-26-2010 04:16 AM
All times are GMT -7. The time now is 07:26 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
