02-27-2013, 06:24 AM   #1
Reinisable
Guest
Camera doesn't recognize lens
Hello, I just bought a Pentax-A 50mm f/1.7 from ebay and after shooting only a couple pictures with my Pentax K-r, the display started showing "F - - " of aperture settings and the shutter speed window became blank, so the the camera doesn't do anything what I press the shutter. Once I changed the lens everything was back to normal, but putting on the 50mm lens on still prevents me from taking pictures and I can't figure out why. One thing is that I accidentally left the focus switch on AF while taking those first two shots.
What can be done to fix this problem?
02-27-2013, 06:32 AM   #2
TenZ.NL's Avatar
Switch to MF, it`s a manual focus lens
If the autofocus can`t lock the camera won`t work (actually it can but that has to be set in the menu). Those first 2 shots must have been in focus accidently.
Furthermore make sure "use aperture ring" is enabled in the menu and set the aperture-ring of the lens on "A". Than it should work in Av or M.
02-27-2013, 11:44 AM   #3
Not positive this is true for the KR. It is true of the newer cameras. An A series lens should be recognized by the camera if the aperture setting is in the A position. It will work in auto-focus mode as a catch in focus.
02-27-2013, 11:52 AM   #4
TenZ.NL's Avatar
QuoteOriginally posted by Colbyt Quote
IIRC this also worked for my K100d and K20d. I could be wrong since I rarely use M- or A-lenses.
F-- is not good, if the aperturering is set to "A" (could be just dirt, clean contacts) but when not, it`s normal because you override the camera with the lens-setting.
02-27-2013, 03:14 PM   #5
QuoteOriginally posted by Reinisable Quote
Setting the aperture ring to A should solve your issue. To use the aperture ring, you have to follow these steps (or just use Av mode to control aperture electronically): https://www.pentaxforums.com/forums/pentax-lens-articles/110657-how-use-meter...k-x-k-7-a.html
02-27-2013, 06:32 PM   #6
hks_kansei's Avatar
Here's my expertise! (well..... experience)
I pretty much exclusively use A series lenses on my *ist.
For starters, using the A lens with teh switch to autofocus won't do any harm, it will just mean the camera will refuse to take a picture unless it thinks it's focussed.
As for the F-- message, that happens because the camera is unaware of the aperture setting, when the Aperture is set to A it should show the current aperture on the LCD.
Step one:
Check the aperture is set to A and not anything else (easy to forget)
Step two:
if the issue still happens try moving the aperture ring off A, and then back on. Occationally the little ball that tells the camera it's set to A can get stuck and doign this can wiggle it free.
Step three:
take the lens off and visually confirm the ball moves in when aperture is set to F22, adn then pokes out slightly then set to A
also look on the cameras lens ring and make sure the contacts are all clean.
If the little ball (on the lens) is stuck you might need to look into something to fix it. (try to avoid taking the lens apart... it took me about 3 hours of magnifying glass, tweezers, and swearing to get that little bastard back properly)
02-27-2013, 06:35 PM   #7
hks_kansei's Avatar
QuoteOriginally posted by TenZ.NL Quote
If the lens is set to A then there should be no need to enable the aperture ring setting.
If it's not detecting the aperture when set to A there's something wrong, either with the lens, or the camera.
02-28-2013, 04:25 AM   #8
Kona's Avatar
As said, make sure it's properly in A mode, and clean the contacts. The lens does work perfectly well on the K-r; I had one, and it was a great lens. You do have to set the FL when turning on the camera, though. It defaults to 50 so is a non-issue.
50mm, camera, lens, pentax help, pictures, shutter
Samsung doesn't deny Android-based camera jogiba Non-Pentax Cameras: Canon, Nikon, etc. 2 03-17-2012 05:59 AM
Camera doesn't react fmerges Pentax K-5 12 02-18-2012 09:02 AM
K-7 Doesn't Recognize the 18-55mm WR Kit Lens cbaytan Pentax DSLR Discussion 17 03-09-2010 10:50 PM
My K10D doesn't recognize my SD card anymore Slowpoke Rodriguez Pentax Camera and Field Accessories 5 11-08-2008 05:32 PM
Need help: Remote Assistant 3 doesn't recognize my K10D VPT Pentax DSLR Discussion 5 10-11-2008 07:56 AM
All times are GMT -7. The time now is 06:20 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
