04-01-2013, 12:55 PM   #1
Joan Jenkins
Guest
Pictues too orange or too yellow
My pictures of oak cabinets always come out too orange or too gold. Is there an adjustment on the Pentax K-x? Thank you
04-01-2013, 01:18 PM   #2
normhead's Avatar
You need to do a white balance in PP. If not, we need to know what lights you're shooting with and what your white balance is set too.
Turn on your Camera. On the little four segmented circle around the "OK" button, you'll see on the left side, a button labelled WB. USe the up and down arrows to select the kind of light you are shooting with, or if the oak is too yellow, set it to the light bulb symbol and press "OK". That should do it.
04-01-2013, 01:28 PM   #3
JinDesu's Avatar
Can you post some pictures?
Are you shooting jpeg or RAW?
04-01-2013, 02:17 PM   #4
Moderator PEG Judges
Kerrowdown's Avatar
If you do any PP, these are quite easily sorted out then, if not follow normheads suggestion and that will sort it in camera.
04-03-2013, 02:50 PM   #5
Use a grey card to set a special WB profile.
There should be a chapter about adjusting WB by using a neutral grey card in the K-x manual.
Of course, this does not apply to flash exposures. For these, the camera provides a correct WB setting.
EDIT: If you don't have a grey card at hand, a black&white newspaper may give you about the same results.
camera, pentax help
Nature Too Busy or Not Too Busy? gmans Photo Critique 11 03-16-2013 12:27 PM
Too little, too much black and contrast. lbenac Film Processing, Scanning, and Darkroom 7 11-23-2010 09:52 PM
Are we too odd as well as too few or is it just me? jptreen Pentax DSLR Discussion 72 10-09-2009 02:59 AM
K-7 gets too hot too fast therion Pentax DSLR Discussion 15 08-18-2009 12:14 AM
HDR(s) whats your opinion? Too many/ too little? Luciferase Digital Processing, Software, and Printing 40 02-23-2009 09:36 AM
All times are GMT -7. The time now is 08:46 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
