05-16-2013, 11:33 PM   #1
Gabriele Lunardi
Guest
moving power zoom
I have just purcheased an old power zoom lens to find out that it's not working on k100.
How can I zoom it manually? May I apply x volts to the contacts to move it to another position? How can I do it ?
Tnx
05-17-2013, 12:57 AM   #2
from what I remember, you can slide the zoom ring forwards or backwards to switch between power and manual zoom mode. you will hear a small click sound when you slide it.
I believe it is the backward slide to change to manual zoom mode.
QuoteOriginally posted by Gabriele Lunardi Quote
Tnx
05-17-2013, 04:24 AM   #3
Stone G.'s Avatar
pakinjapan is right.Here's what the Pentax FA Lens Manual (2002) says about the subject:
QUOTE:
"When combined with non-KAF2-mount cameras, FA Zoom lens with power supply contacts does not work following functions.
• As the Power Zoom function does not work, set the manual zoom mode. Pull the zoom ring towards the camera side until the words "POWER ZOOM" disappears to set the manual zoom mode.
• The Auto Zoom switch and Zoom Set button do not work
Using the power zoom
Push the zoom ring forward until the word "POWER ZOOM "appears on the ring, and move the zoom ring to right or left to change the focal length.
Using the manual zoom
Pull the zoom ring back to use as manualzoom ring, the word "POWER ZOOM" disappears
END OF QUOTE
Hope, that helps?
05-17-2013, 07:12 AM   #4
Tnx
As others have said, just pull the ring back and then you can zoom manually.
For the record, Pentax's high-end DSLRs do support power zoom. This includes, the K-5, K-7, K20D, and K10D models.
05-17-2013, 02:56 PM   #5
@ the OP
@ Adam
I can't verify it myself, but I repeat one of my older postings:
The K10D, K20D, K-7 do support power zoom, the K100D, K200D, K-x, K-r don't, so it's not old versus new.
About the *istD models I am not sure.
There is a list from 2009 by falc
https://www.pentaxforums.com/forums/p...explained.html
(post #4)
K-5 wasn't out in 2009.
EDIT: If this list is correct, Powerzoom will not work with the K100 of the OP.
05-17-2013, 09:18 PM   #6
Ken T's Avatar
Powerzoom works on my K-10D and K-20D too, but not on my K-30 .
camera, pentax help, power
Pentax K-7 LV zoom in moving screen striker_ Pentax DSLR Discussion 7 02-21-2012 10:07 AM
Pentax 100-300 power zoom lens slackercruster Pentax SLR Lens Discussion 4 02-08-2012 01:23 PM
missing switch on 28-80mm power zoom paulmboat Troubleshooting and Beginner Help 7 01-01-2012 02:13 PM
K10D with Power Zoom Lens BKSande Pentax DSLR Discussion 9 11-20-2011 01:27 PM
Zoom/Power zoom on flashes: why? hray Troubleshooting and Beginner Help 11 03-03-2011 03:02 PM
All times are GMT -7. The time now is 01:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
