05-19-2013, 01:24 PM   #1
Gary Coles
Guest
Looking To Upgrade
Can I use my istD lenses on a K-5 series body?
05-19-2013, 01:44 PM   #2
Moderator PEG Judges
Kerrowdown's Avatar
Without knowing which lenses your actually talking about, you will find that most Pentax lenses are backwards compatible, with differing levels of functionality.
It's one of the joys of being a Pentax owner.
05-24-2013, 07:56 AM   #3
If one of your lenses is the first version of the kit lens (DA 18-55): Resolutionwise this was designed for the 6MP sensor.
With the 10MP sensor of the K10D / K200D / K-m(K2000) it was already at its limit.
The 14MP sensor of the K20D / K-7 clearly outresolved this lens, so Pentax replaced it with the DA 18-55 II. The optics of this are identical with the cheaper DAL 18-55 and the more expensive DA 18-55 WR. All 3 are still good enough (resolutionwise) for the 16MP of the K-5 / K-01 (just).
However, if you don't look at your pictures at stronger magnifications than you did with the *istD, you may not see a difference.
05-24-2013, 08:11 AM   #4
It will work fine.
Tim
camera, pentax help
Looking for upgrade advice Kaitain Pentax K-30 & K-50 10 01-03-2013 04:46 PM
KX Owner Looking To Upgrade To The K30 Indopunk Pentax K-30 & K-50 10 07-30-2012 09:14 AM
Looking to upgrade zooms - question ChrisOBrien Pentax SLR Lens Discussion 2 09-08-2010 09:53 AM
Looking to upgrade bodies mediaslinky Pentax DSLR Discussion 13 08-01-2008 05:00 AM
All times are GMT -7. The time now is 06:32 PM. | See also: NikonForums.com, part of our network of photo forums!
