05-25-2013, 10:25 AM   #1
hendrik joubert
Guest
k30
I have a k30 which seems to freeze up after i take a photo, so when i try to adjust anything it doesnt work, but when the camera goes into sleep mode and you press the shutter then it works when adjusting,what is wrong
05-25-2013, 02:51 PM   #2
Try to make a full reset (the manual somewhere tells how to do it). If this doesn't cure it, try another SD card.
If these steps don't help, you'll have to wait if there is some K-30 owner responding who had a similar problem (and, hopefully, solved it).
EDIT: Also, problems with the batteries can cause all kind of weird errors.
05-25-2013, 02:54 PM   #3
MarkJerling's Avatar
QuoteOriginally posted by hendrik joubert Quote
Hello Hendrik
Based on what you're describing, it could be an issue related to write speed to the SD card. I trust you have a good, fast SDHC / SDXC card in there?
Are you on the latest firmware update? (1.04)
Lastly, is your battery fully charged?
Good luck!
Hoop dis so iets eenvoudig!
Regards,
Mark
06-20-2013, 06:10 AM   #4
altopiet's Avatar
Hendrik, I agree with Mark, before I did the firmware update to 1.04, I had the same problems, but after that everything is fine...
camera, k30, pentax help
K30 nitpicks. tuggie76 Pentax K-30 & K-50 15 05-19-2013 04:13 AM
K30 newbie patharan Welcomes and Introductions 2 11-26-2012 07:18 PM
Blue K30? synapsestorm Pentax K-30 & K-50 21 07-27-2012 05:00 PM
All times are GMT -7. The time now is 04:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
