06-12-2013, 10:16 PM   #1
John Branum
Guest
Flash compatibility
I just bought a k30 and would like to know if my Pentax flash 500ftz will work on it.
06-13-2013, 12:38 AM   #2
carrrlangas's Avatar
yes it will. But it is a TTL flash. Pentax newest DSLRs support only P-TTL which is the "evolution" of TTL. So in short, you can use the flash on manual mode or auto mode if it has a thyristor.
06-13-2013, 03:55 PM   #3
Banned
The Pentax *ist DS2 was the last DSLR with TTL flash compatibility.
https://www.pentaxforums.com/forums/pentax-dslr-discussion/57922-ds2-ttl-flash.html
06-14-2013, 10:09 AM   #4
sawtooth235's Avatar
QuoteOriginally posted by John Branum Quote
It will fire, set the shutter speed, indicate in the viewfinder when it has recycled and it will provide auto-focus assist lighting, but it will not operate automatically. You will have to use it totally manually and the camera will have to be set to manual operation with you selecting the correct aperture. The screen on the back should provide you with the information you need to set the aperture correctly, but you will have to do some calculations.
Ray
camera, flash, pentax help
Old Flash Compatibility sai Flashes, Lighting, and Studio 4 11-24-2012 10:55 AM
Flash compatibility Tigerpelle Pentax K-30 & K-50 8 08-31-2012 01:33 AM
Quantaray Q15 flash compatibility stainsor Pentax DSLR Discussion 2 11-01-2011 07:28 PM
flash compatibility dave- Pentax K-r 3 10-13-2011 06:54 AM
Flash Compatibility Max-E Pentax K-r 5 08-21-2011 11:22 PM
All times are GMT -7. The time now is 07:14 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
