08-06-2013, 10:47 AM   #1
Leonski, Macedonia
Guest
Best lens for portrait
Lens for photoportrait: DA* 55mm or DA 77mm or DA* 50-135mm? Best?
All the best from Macedonia.
08-06-2013, 11:00 AM   #2
enoeske's Avatar
what type of portrait? headshot? full body? multi-person? posed or candid? natural light or studio lighting?
My favorite is the Sigma 85mm f/1.4
08-06-2013, 11:01 AM   #3
PEG Moderator
Kerrowdown's Avatar
QuoteOriginally posted by First Poster Quote
I'd go for primes, the DA55 on APS and DA77 on FF.
08-06-2013, 11:03 AM   #4
jatrax's Avatar
That would be FA 77, the DA is 70mm and it is also very good.
Best? I think you would be hard pressed to fault any of the 4 but they do have different features. 50-135 is more versatile, 77 and 70 might be a little too long for some portrait styles. I've used the DA 70 and found the results quite good but had to switch to DA*16-50 with two people in the frame as I could not back up enough. But really I don't think you will be disappointed with any of these.
08-06-2013, 02:09 PM   #5
hcc
hcc's Avatar
I would second the FA77mm Ltd. Some PF members recommend the DA*55mm, but I prefer the longer focal length of the the FA77 Ltd.
If you need to shoot portrait in low light, the large aperture of the FA77mm might be an asset.
My 5 cents....
08-06-2013, 02:12 PM   #6
JinDesu's Avatar
I would say either the DA*55 or the Sigma 85 F1.4
08-06-2013, 03:09 PM   #7
For portraits taken in narrow rooms 55-60mm would be the optimum.
Longer will often be too limiting. On APS-C, 77mm is already a real tele lens.
Outside and in studio, up to 80mm is still ok.
Longer than that, sometimes faces may already look a bit flat.
But this will also depend on how well you can control light.
08-06-2013, 03:31 PM   #8
RobA_Oz's Avatar
Just to confuse matters, I'd generally choose between the Pentax FA43, FA77 or DA*50-135, but I'd also throw into the mix the Voigtlander SL 58/1.4. I'm lucky enough to have all of these, and I'd choose the FL according to the situation. The 50-135 is the most versatile, of course, but not so much indoors, unless you're shooting in a big room in good light. On the other hand, in a tight space, I've been known to use my FA*24 or even my FA20 for full or half-length portraits. Confusing, isn't it?
Nonetheless, if you're settling on a 50-ish minimum FL, I'd highly recommend the Voigtlander, if you can find one. The additional maximum aperture is useful, over the 50-135, and the colour rendition is unique.
camera, da*, lens, pentax help
Best background for portrait lepiallou Digital Processing, Software, and Printing 7 02-28-2013 09:40 AM
What is the Best Focal Length for a Portrait Lens? Drom Pentax SLR Lens Discussion 94 04-22-2012 02:00 PM
Whats the best portrait lens for a K20D? jeryst Pentax DSLR Discussion 50 11-07-2011 06:13 AM
Best portrait lens of all time? ronpyke Pentax SLR Lens Discussion 46 09-03-2011 06:00 AM
Best choice for a long, prime portrait lens? m88k Pentax SLR Lens Discussion 23 08-11-2010 03:13 PM
All times are GMT -7. The time now is 02:02 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
