08-13-2013, 10:07 AM   #1
Richm
Guest
Telephoto Lens For K100 Super D
I have old telephoto lens 80 to 200 lens. But when I to use with my super D. When I turn on the camera, the LCD panel The AV blinks off and on
and just reads AV__ __ . I also purchased a sigma 70 to 300 lens and the same problem. The AV icon blinks on and off and nothing works. The crazy thing is the standard lens works just fine.
08-13-2013, 11:27 AM   #2
QuoteOriginally posted by Richm Quote
You need to go into the custom setting and select 'enable aperture ring' - then they will work properly (also make sure to set the aperture ring to the A setting).
08-13-2013, 02:18 PM   #3
You don't tell us the exact specification of the lenses.
If the lens(es) don't have an "A" setting, you can use it in "M" mode only, with stop down metering.
Of course, also the use of the aperture ring must be enabled somewhere in the settings menu.
As default Pentax delivers it disabled, but leaving it enabled generally does not do any harm.
av, camera, lens, pentax help, telephoto, telephoto lens
Help please with K100 D Super alisonkim Troubleshooting and Beginner Help 11 02-13-2012 07:00 PM
k100 d super won't go into auto flash mode tdmsu Troubleshooting and Beginner Help 2 11-04-2011 05:17 AM
K100 D Super T Edwards Pentax DSLR Discussion 3 03-06-2010 10:42 AM
Best short FAST zoom lens for K100 Super audio_mad Pentax SLR Lens Discussion 3 03-02-2009 12:24 PM
k200D vs. K100 Super D LSC Pentax DSLR Discussion 2 07-27-2008 09:23 AM
All times are GMT -7. The time now is 08:55 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
