09-03-2013, 04:51 PM   #1
Frieght train
Guest
K1 wont focus at infinity
When shooting the k1 with the pentax 16-45 lens, the camera sometimes will auto focus the lens. I really notice it when i stop down the lens to f11 and
focus at infinity.
09-03-2013, 05:30 PM   #2
It is most likely the lens,
09-03-2013, 11:08 PM   #3
hcc
hcc's Avatar
The first thing is: have you updated your firmware? The latest K-01 firmware has improved the AF.
Second, do you have the problem in low light? In the affirmative, it is normal: the AF of the K-01 is not at best in low light/
Third, as suggested by Primes4ever, it may be the lens which does not pair well with the body. With my K-01, I found that the small light lenses works best (eg DA40mm, DA 15mm). Some zoom lenses do not work well (eg DA18-250mm) in AF. In these situations, you can always use MF.
Hope that the comment may help.
09-04-2013, 03:26 AM   #4
Na Horuk's Avatar
Can you try the lens with a different camera?
Can you focus to infinity if you use MF (manual focus)?
camera, focus, infinity, k1, lens, pentax help
Using old screw mount asahi lenses wont focus to infinity??? carlyn.warnock Pentax SLR Lens Discussion 19 11-28-2012 10:24 AM
Da* 55mm 1.4 wont af at infinity Wired Troubleshooting and Beginner Help 4 08-04-2012 01:52 PM
Pentax DA 50-300mm wont focus to infinity??? TopherTheME Pentax SLR Lens Discussion 5 12-04-2011 07:02 AM
Focus at infinity veebs2 Troubleshooting and Beginner Help 16 03-06-2010 01:47 AM
SMCP-F 7-210 f4-5.6 wont focus to infinity on Ds? Quenchfire Pentax SLR Lens Discussion 3 10-30-2006 12:18 AM
All times are GMT -7. The time now is 09:48 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
