01-13-2014, 08:15 AM   #1
MRP1
Guest
cant see anything through my view finder of Pentax K1000
Due to use of Digital camera I had not used my Pentax K1000 since may be four years.Now when I wanted to use it I am not able to see anything through my view finder and everything is dark. I have changed the battery to no avail.Any solution.
01-13-2014, 08:45 AM - 1 Like   #2
savoche's Avatar
I suppose you've removed the lens cap (duh), so it sounds like the mirror is locked in the open position. Can you see the mirror if you look through the lens mount with no lens on?
01-17-2014, 06:49 AM   #3
altopiet's Avatar
QuoteOriginally posted by savoche Quote
I agree, probably stuck to the foam around the frame which degrades and gets a bit sticky with age....just pull lightly at the edge as you look from the front and see if it flips back down...
01-20-2014, 06:17 AM   #4
QuoteOriginally posted by altopiet Quote
Then send it off to Eric, for repair
Home
02-11-2014, 10:17 PM   #5
usually happens if you take your lens off when it is in lock up position.... is your camera set to bulb.. if so change it
02-14-2014, 04:06 PM   #6
Senior Moderator
Parallax's Avatar
It's been many years, but isn't there a mechanical mirror lock switch on the side? Did you check to make sure it isn't in the up position?
02-14-2014, 04:08 PM   #7
boriscleto's Avatar
QuoteOriginally posted by Parallax Quote
Not on the K1000. The K2 & KX had mirror lockup, but not the KM or K1000.
02-14-2014, 09:38 PM   #8
altopiet's Avatar
http://www.pentax-manuals.com/markroberts/k1000_man.pdf
camera, finder, finder of pentax, k1000, pentax, pentax help, view, view finder
People I cant see, I cant see!!! Kerrowdown Post Your Photos! 4 11-18-2013 01:18 PM
View finder vs Live View on K5 II Wingincamera Pentax K-5 5 12-08-2012 03:47 PM
Cant see anything on Page 2 thread .. daacon Site Suggestions and Help 12 02-03-2009 04:50 AM
New Zealand through the view finder. Pt 1. Mallee Boy Post Your Photos! 4 05-17-2008 05:01 PM
i cant view or open RAW images on my pc,, distorted_vision Photographic Technique 13 11-23-2007 06:19 PM
All times are GMT -7. The time now is 04:15 AM. | See also: NikonForums.com, part of our network of photo forums!
