04-02-2014, 07:28 AM   #1
Jay Thornburg
Guest
Old Bayonet mounted lenses
I have an old, film, ME Super with several bayonet-mount, manual lenses. I would like to replace this with an equivalent DSLR, but, after reading several of the posts, I am still confused about which will work. None of these lenses have an "A", all have a manual F-stop and focus. Can someone simplify things with:
1. Which model Pentax body should I buy?
2. Will I need a lens adapter ring? If yes, what model?
3. Am I doomed and should I just buy a new DSLR and start over? I really like my 135mm portrait and 500mm lenses.
04-02-2014, 07:42 AM   #2
Senior Moderator
Parallax's Avatar
There's really no need for confusion. If the lenses are Pentax mount, the will work on any Pentax DSLR. If they are screw mount you will need and adapter, but if they are, as you say, bayonet mount then no adapter is needed.
https://www.pentaxforums.com/forums/58-pentax-beginners-corner-q/110658-using...x-dslrs-f.html
04-02-2014, 07:52 AM   #3
Jay Thornburg
Guest
Old bayonet lenses
Thanks...can you recommend a new DSLR body with equialent function and quality of my ME Super?
04-02-2014, 07:53 AM   #4
wtlwdwgn's Avatar
Welcome to the forum Jay! No, you won't need an adapter to use any K mount lens on any Pentax digital body. Those older lenses have a huge following here on PF. Search the forum for using the aperture ring on a digital body. Which body to buy is determined more by your budget. There are also many used bodies and lenses in the Marketplace. I started with a K10D and then moved on to a K20D, a K-5, and now a K-3. I've also seen some good images here on PF from the K-30 and K-50. I hope I've been helpful and look forward to seeing your images.
04-02-2014, 08:56 AM   #5
QuoteOriginally posted by Jay Thornburg Quote
Any of the current Pentax dSLR line will have feature sets that are much beyond your ME Super. In my opinion the K-50 is probably the best value.
04-02-2014, 09:01 AM   #6
Jay, I started out with a K-1000, and made the jump to digital when I bought my K-30. I love the camera. The manual lenses are marvelous with it, once you figure out the buttons and settings.
I did feel a bit let down when they introduced the K-50 so very soon after the K-30, but have not felt compelled to "upgrade"...the K-30 was a comfortable choice and I'm glad i bought it. From what I've seen, you can get a K-30 body only for as low as about $300 on the Marketplace here...a fact that (having bought mine new in January of last year) kinda makes me cringe at what I paid for mine!
But as a first digital camera, I'm glad I chose the K-30. And that 18-135 kit lens is no slouch, either...although it did contribute to me putting off turning that dial away from "AUTO" for a longer time than it should have!
And you've found the right place to ask questions...wondrously helpful and friendly folk abound!
04-02-2014, 08:58 PM   #7
AquaDome's Avatar
The K-30 and K-50 are pretty much identical. I have a K-50 that I use old lenses on almost exclusively. The M and A lenses are too good to pass up.
04-02-2014, 09:39 PM   #8
maltfalc's Avatar
k-30 if you're buying used and find one for under $350, k-50 if you're buying new (unless you find a new k-30 for significantly less).
04-03-2014, 06:18 AM   #9
Your favorite lenses are going to be cropped so they shoot like:
135mm=200mm
500mm=750mm
04-03-2014, 07:16 AM   #10
Senior Moderator
Parallax's Avatar
QuoteOriginally posted by Sliver-Surfer Quote
135mm=200mm
500mm=750mm
OP - See my sig line.
04-03-2014, 11:25 AM   #11
TER-OR's Avatar
Really, just remember the lenses won't give you the same field of view on the new DSLR, that's all. A 50mm on your film body will "look" more like a 70ish mm on an APS-C body. That's all - you may find yourself wanting something on the wider end.
You'll want a body with two control wheels, making it easier to control your settings.
Also consider buying a camera with the focus screen swapped for a split-focus screen or installing one yourself. I had one on my K10 and it does make manual focusing much easier.
Beyond that, any of the cameras will work for you. A K30 is a good value, but so are used K5s. There are also threads about the focus screens, you'll find them.
04-03-2014, 04:30 PM   #12
QuoteOriginally posted by Parallax Quote
I use FF and aps-c... life is difficult
04-03-2014, 05:07 PM   #13
Senior Moderator
Parallax's Avatar
04-11-2014, 08:34 PM   #14
zekewhipper's Avatar
Be mindful that the lenses you want to use don't have the Ricoh pin problem.
camera, dslr, lenses, model, pentax help
For Sale - Sold: Pentax SLR Film Cameras (bayonet), Lenses, Accessories and Manuals bluemoose Sold Items 3 02-19-2014 03:34 PM
Bayonet rear lens caps for Q lenses? Docrwm Pentax Q 11 12-13-2012 03:58 PM
Utilizing Old K mount and Bayonet Mount Lenses jk333 Pentax SLR Lens Discussion 11 08-15-2010 01:30 AM
K200d and 20 yr old lenses w/bayonet TeeDub Welcomes and Introductions 4 05-17-2009 11:09 PM
All times are GMT -7. The time now is 10:58 AM. | See also: NikonForums.com, part of our network of photo forums!
