04-20-2014, 02:32 PM   #1
Mike uk
Guest
Pentax kx as photo booth camera
Looking for some advise.
I have a Pentax k-x and want to use it in a DIY photo booth for my daughters wedding.
So far I have a remote control trigger and an output cable.
The camera will be set up on a tripod facing a back wall. Guests will be able to set off the camera using the remote control as they face the camera.
A 14inch flat screen TV will be mounted below the camera and attached using the output leads. The camera will be set to Live View so guests can see themselves on the TV screen before they trigger the camera. (We are not worried about printing or viewing photos immediately after they have been taken.)
I have tested the set up and it works fine.
The next problem is getting adequate continuous power to the camera. I have seen instructions on this forum and intend to make my own ac adapter using aaa to aa converters and a dc power unit linked with a female and pigtails to the battery converter.
I have 2 problems,
1. What should the voltage and amperage of the power unit be. I can get hold of 6v 3a and 5v 3a or the same voltages but 4a output so not sure which one to use
2. Will the proposed set up damage the camera. i.e. Is it ok to run the camera in LV mode all night with the output connected to the TV (TV will have its own power supply)
Hiring a booth is way out of our price range so we are trying to do as much as we can ourselves.
I'd really appreciate any advice you can give me
Thanks
Mike
04-20-2014, 02:35 PM   #2
If you can acquire one of these it'll offer you peace of mind:
Pentax K-AC84 AC Adapter Kit (includes D-AC76 and D-DC84) reviews - Pentax Camera Accessory Review Database
And the sensor will probably overheat after a few hours, so I would recommend having the camera go to sleep when it is not being used. Alternatively set up a power button for users or something like that
04-20-2014, 06:42 PM   #3
Energizer ultimate lithiums should last the night if you are letting the camera go to sleep. Use makeshift modelling lights instead of flash
04-22-2014, 07:45 AM   #4
Mike uk
Guest
Thanks guys.
I do not really want to keep turning the power on and off because each time I will need to reset it to LV mode. The whole idea is for me to set it up and leave it unattended for the night.
My main concern is 'cooking' the camera so maybe I will have to close the booth every hour for 10 minutes while it cools itself down again.
Thanks again.
booth, camera, kx as photo, output, pentax help, pentax kx, photo booth, power, tv, unit
Considering Pentax Kx camera as upgrade fevbusch Pentax DSLR Discussion 31 07-29-2013 03:18 AM
Fun-raiser event photo "booth" tips ? astonm Photographic Industry and Professionals 2 04-12-2013 05:52 AM
kx photo with 55-300mm lens af works,but as a newbe to manual focus litboat Troubleshooting and Beginner Help 4 11-07-2010 05:04 PM
Question on how to get photo as sharp as this with Pentax ? shadowbecomeswhite Troubleshooting and Beginner Help 22 03-24-2010 06:18 AM
Photo booth setup Eigengrau Pentax Camera and Field Accessories 4 08-19-2009 08:34 AM
All times are GMT -7. The time now is 10:01 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
