06-04-2014, 08:50 PM   #1
Niktank
Guest
Optio S10 won't to stay ON
My Optio S10 is turning ON (the lens is opening wide, the LCD is lighting) but after a second the camera is turning OFF (the lens is retracting and the LCD is dark again). It is repeating every time. I checked the battery and the battery connections, the SD card is formatted also but the problem is still remaining.
Thank you if you can help me.
06-04-2014, 08:54 PM   #2
Is the battery old? You might need to pick up a replacement if so.
06-04-2014, 09:02 PM   #3
Niktank
Guest
The battery is about 4 years old and it is the original one. I never had battery charge problems or short time of functioning.
I suspect more some infection of the firmware because I put my SD card to a infected comp ( I had to erase everything on the card - even the Pentax files ) and short time after that I had the problems.
Thanks for your help.
06-04-2014, 09:29 PM   #4
OregonJim's Avatar
QuoteOriginally posted by Niktank Quote
A virus will not infect your camera. It uses a different CPU that couldn't run virus code if it wanted to.
I had an Optio S12 that did what you describe if I happened to hold my finger on the power button a little too long. Might you have spilled something on the camera that is making the power button sticky?
Adam is probably right - four years is pushing it for a rechargeable battery of any type.
06-05-2014, 02:06 PM   #5
Usually Li rechargeable batteries have a lifetime of 3-6 years, depending on how they were used.
After 4 years, even with a very good charging management, reaching 30% or more of the original capacity would be an exception.
battery, camera, lcd, lens, optio, optio s10, pentax help, s10
Rz18 won't stay on SandraB Visitors' Center 5 02-24-2014 04:41 PM
Optio s12 won't switch on? Phil1888 Troubleshooting and Beginner Help 2 12-18-2011 03:52 PM
Popup flash on PZ-70 won't stay down neal_nelson Pentax Film SLR Discussion 6 09-11-2009 02:14 PM
AF540FGZ - won't stay on hot shoe ksignorini Flashes, Lighting, and Studio 8 05-23-2008 09:43 PM
All times are GMT -7. The time now is 01:58 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
