06-21-2014, 10:28 AM   #1
Pat Tindall
Guest
Fotodiox adapter stuck on Pentax lens
How do I get it off? Without damaging the lens, I mean?
06-21-2014, 10:48 AM   #2
Is it safe to assume that it is a K-mount to non-Pentax camera adapter? If so, there should be a release button on the adapter. If that is defective, a Dremel tool with cutting disk might work.
06-21-2014, 10:49 AM   #3
Well, there goes the hammer idea. If the lens is truly expensive, I would suggest calling fotodiox for support. If you can't do that, I would probably very carefully have a dremel to the fotodiox while protecting the lens.
06-21-2014, 11:08 AM   #4
ramseybuckeye's Avatar
If the adapter is off the camera and the adapter's release is not working, you may be able to look inside and see what the release is not doing, then maybe "help" it. (that is if the adapter does not have glass).
camera, fotodiox adapter, lens, pentax help
Fotodiox Pentax 67 Lens to P645 Camera adapter LaHo Pentax Medium Format 18 01-02-2016 11:58 AM
Settings when using fotodiox adapter and 75-150mm lens LouPapy Pentax Q 3 08-28-2013 07:07 AM
M37 to M42 adapter stuck on lens .a.t. Troubleshooting and Beginner Help 10 07-09-2013 11:32 PM
HELP! Canon adapter stuck on my Pentax lens tomaplaw Troubleshooting and Beginner Help 2 07-12-2011 01:05 PM
HELP! M42 adapter stuck on lens! figmental1978 Pentax Camera and Field Accessories 2 12-27-2007 05:44 AM
All times are GMT -7. The time now is 03:39 AM. | See also: NikonForums.com, part of our network of photo forums!
