07-02-2014, 05:30 PM   #1
Craig Swede
Guest
file name
Can the format of the file name be changed so the a chronological date is used? For example 2014-07-04 Fireworks.xxx [YYYY-MM-DD Description.xxx]
07-02-2014, 05:37 PM   #2
You can't do this in-camera with current Pentax cameras, but desktop software like photoshop can easily batch rename files for you.
07-02-2014, 06:12 PM   #3
jatrax's Avatar
If you do not have photoshop or another capable program, I used for many years a freeware program called Stamp 2.8. Takes a little to set it up the way you want but after that you just run a batch of files through it and it will rename them to just about anything you want, including a date stamp. I used 2014.07.02@11.15.30.jpg for years. And when I moved to Lightroom I just set Lightroom up to use the same format.
07-02-2014, 06:21 PM   #4
calsan's Avatar
I use these:
On windows, nameexif
Namexif: Rename EXIF Photos
On mac, exifrenamer
ExifRenamer for Mac | MacUpdate
07-02-2014, 08:30 PM   #5
ramseybuckeye's Avatar
I use Lightroom and have it rename the files as they are imported from the camera. Here are some actual filenames: 20140702PENTAX K-30-0003, 20140614E-520-0006, 20130702PENTAX Q-0023. I have it setup to use the year, month, day, Camera Name, and three digit series starting at 001. Lightroom also creates a folder with the date. I'm pretty sure you can even put the camera serial number in the name (if you have two cameras of the same model). 20140614E-520-0006 is from my son's Olympus E-520. apparently it does not pick up the name "Olympus" in the exif.
07-02-2014, 08:54 PM   #6
SpecialK's Avatar
I use Renamer v8.2 to change IMGP to YYMMDD (and sometimes do other things) , but I always manually add a brief description ("Church") and on occasion change the sequence number to make the series flow better.
So, it is "140613Church.jpg", and it goes that days' folder "YYMMDD Short Description".
Flexible Renamer
camera, file, name, pentax help
How to Reset the File Name to 100-0001 brosen Pentax K-5 4 03-07-2012 01:29 AM
K-x - file name options 7samurai Pentax DSLR Discussion 2 10-16-2010 08:58 PM
K7 File name Problem Christine Pentax DSLR Discussion 6 04-07-2010 07:52 PM
Folder/file name GordZ Pentax DSLR Discussion 7 02-11-2010 06:12 PM
File name change bwhardy Pentax DSLR Discussion 2 02-13-2007 03:12 PM
All times are GMT -7. The time now is 07:55 PM. | See also: NikonForums.com, part of our network of photo forums!
