07-16-2014, 09:01 PM   #1
William Shepard
Guest
LCD Monitor problem
My LCD monitor does not show anything, but the camera still takes pictures.
07-16-2014, 09:57 PM   #2
calsan's Avatar
Which camera? What happens when you press the play button, what happens when you press any button - does the display turn on?
07-17-2014, 12:45 AM   #3
Try pressing the 'Info' button a couple of times.
07-17-2014, 04:24 PM   #4
William Shepard
Guest
Dr
The camera is a Pentax Optio E 10. I have tried pressing all the buttons, with no result. Perhaps there is some particular sequence required but I have not found it. It does not have a "play" button or an "info" button, or has these under other names. It has buttons for zooming, one with a triangle-like arrow (used to see previously taken pictures), a MENU button, a four-way controller, an OK button.
07-19-2014, 02:07 AM   #5
You have probably inadvertantly turned the lcd display off.
Presumably you don't have a manual to look up the menus...
Here is one for download...
Downloads & Literature - RICOH Imaging
good luck
07-20-2014, 07:57 PM   #6
William Shepard
Guest
LCD Monitor Problem
Thanks for advice and directing me to the manual, which is far more detailed than the one I have. Unfortunately, however, pressing the <OK> button does not make any difference. I should mention that the screen of the monitor is bright when the camera is turned on, but it has no images. This happened very quickly. It was OK, then I did something (i.e. pressed a button or turned the camera off) and there was a very faint image, then the next time no image at all. The batteries had recently been recharged.
camera, lcd, pentax help
K3 - Adjusting LCD Monitor loganross Pentax K-3 5 01-27-2014 01:43 PM
K5II preview monitor has dead Pixel & moisture in viewfinder and LCD screen Amante Troubleshooting and Beginner Help 16 09-04-2013 09:09 AM
K-5II LCD monitor pate Pentax K-5 2 06-09-2013 09:25 AM
New Monitor: LED, LCD, or LCD with Back-light? dmfw Troubleshooting and Beginner Help 11 01-03-2013 05:02 AM
A common garden 17" CRT monitor vs an average 20-22" LCD monitor for image processing bc_the_path Digital Processing, Software, and Printing 6 07-11-2009 02:28 PM
All times are GMT -7. The time now is 12:21 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
