08-19-2014, 09:06 PM   #1
Julie Coleman
Guest
IR filter
Hi, I have recently bought a IR filter but have not been able to get any good results. I am just a beginner to this sort of advanced photography, does anyone have any tips.
Thanks
08-19-2014, 09:38 PM   #2
QuoteOriginally posted by Julie Coleman Quote
Thanks
Shoot on sunny days, use a wide angle lens or focal length, and make sure that your IR filter really is an IR filter and not some fakery, and you should be able to achieve decent results.
Here is an excellent guide:
http://www.digitalcameraworld.com/2012/07/09/how-to-shoot-haunting-digital-i...d-photography/
08-20-2014, 09:08 AM   #3
Emperor and Senpai
VoiceOfReason's Avatar
Unless you've had a camera converted to full spectrum or IR then you will have to use live view for focusing, have it on a tripod, and then do a longer exposure. Your images will look a bit red, so set your white balance on a tree or grass, so your green will look like a white or light pink. Then using photochop swap the red and blue channels by setting blue to 100 and red to 0 in the red channel, and red to 100 and blue to 0 in the blue channel, then flatten the image, then do auto tone, then auto contrast. The results can be beautiful.
camera, filter, ir, pentax help
IR filter failures Vitalii Photographic Technique 6 08-04-2014 07:33 PM
Can I remove the IR Filter of Pentax Q? ElvisQ Pentax Q 8 05-25-2013 11:03 PM
IR and Polarizer filter tests sunglint Pentax K-01 4 12-08-2012 07:33 AM
IR filter rundown slackercruster Pentax DSLR Discussion 4 03-27-2012 01:10 PM
IR filter removal??? pntxjack Pentax DSLR Discussion 5 05-08-2008 02:20 PM
All times are GMT -7. The time now is 06:45 AM. | See also: NikonForums.com, part of our network of photo forums!
