11-12-2014, 05:55 AM   #1
Rysard
Guest
Pentax X-5 turning off
Hi,
Why pentax x-5 turns on and then turns off without reason?
Tank you.
11-12-2014, 07:05 AM   #2
flaviopetrone's Avatar
Hi, I don't have an x-5 so I can't help you but if you explain better the problem, when it happens and if you tried to do something, I am sure that someone here will help you.
11-12-2014, 10:40 AM   #3
Canada_Rockies's Avatar
My wife uses an X-5, and one annoyance to me (not to her) is that the camera will not turn on when the lens cap is mounted.
11-15-2014, 06:08 AM   #4
Mikesul's Avatar
You need to give us more detail about when the problem happens and your camera settings. Are you sure that the battery is fully charged?
03-18-2015, 12:43 PM   #5
Carrie
Guest
Same problem
I'm having the same problem. My lense cap is off, batteries are charged. I turn on my camera to use it. The on light lights up and the display lights up and then it all turns off. It turns on but won't stay on. Thanks.
03-20-2015, 03:08 AM   #6
Carrie
Guest
Ms
Update. After some research on the web I put in a new memory card and new batteries in and it's now working. It has something to do with static charges????!!!! Which can occasionally damage the SD card. Anyway, it works now. I'm very pleased.
camera, pentax, pentax help, pentax x-5, x-5
Turning off timer alouise Troubleshooting and Beginner Help 2 12-30-2013 01:12 AM
Camera hung after turning off in LV garywakeling Pentax K-3 3 11-17-2013 09:59 AM
turning display off Bill G Pentax K-30 & K-50 2 10-14-2013 03:38 PM
turning K-01 LCD off? Ecaterin Pentax K-01 6 12-21-2012 07:42 PM
K-5 - Turning off the Histogram in Replay Mode jeallen01 Pentax K-5 2 03-26-2011 04:20 PM
All times are GMT -7. The time now is 05:11 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
